How to remove electrochrome mirror?
Old Nov 15, 2004 | 10:41 PM
saber's Avatar
saber
Default How to remove electrochrome mirror?
Title says it. I want to remove my mirror, fix the led connection on one side and tap into the 12V for my radar dectector. The mirror mount does not have the standard set screw mount.
Thanks in advance.
Old Nov 15, 2004 | 11:04 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I slides off, from what I understand. It is a wedge style mount. I could be wrong, Just pull up.
Old Nov 17, 2004 | 02:52 PM
saber's Avatar
saber
I tried pushing on it but it will not move.
Can I tap it?
Old Nov 17, 2004 | 03:45 PM
screw991le's Avatar
screw991le
I just installed mine and after getting it on, and snapping into place I just pulled up toward the roof and it came off, hard but it came off.
Old Nov 17, 2004 | 04:01 PM
mnotx's Avatar
mnotx
There is a flat spring in the mirror base with two little locking tabs that snap down to lock the mirror onto the windshield base. Use a flashlight and look at the mirror mount through the windshield and you will see the two locking tabs.
These two tabs need to be pulled down enough to clear the windshield base and the mirror will then slide off. A small, short jawed vice grip works great. You can clamp the spring down and the mirror will slide on and off easily.
Old Nov 22, 2004 | 11:00 PM
saber's Avatar
saber
Thanks guys I did it but, kind of a pita
Old Nov 23, 2004 | 09:14 PM
bcseitz's Avatar
bcseitz
Now that the mirrior is off, can anyone help and share info on what is the cleanest way to tie into and mount a new Escort X50 ??
Thanks Guys......
Old May 12, 2016 | 06:40 PM
f1reb1rd's Avatar
f1reb1rd
Default 04 rearview mirror removal
the spring is short and stiff i used a long needle nose pliers to squeeze down on both togather then the entire mirror assembly slid towards the top of the glass slides towards the top of the glass
Old Jul 11, 2020 | 10:07 AM
Cherrywine362's Avatar
Cherrywine362
Default Spring Latch Mirror Tool
The autodimming (electrochromic) mirror on my 2003 C5 50th Anniversary did not have a screw holding it down like manual (non-autodimming) mirrors. I found out it has what's called a "Spring Latch" mechanism like older Ford mirrors. Fearful of breaking the windshield in my many unsuccssfull attempts in removing the mirror, I found this tool used by auto glass techs:
​​​​​​Made things a lot easier. Hope this helps someone.
To How to remove electrochrome mirror?
