Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- C5 Corvette: General Specifications and Information
Important information to help you understand your Corvette.
Weights, measurements, ratios, strengths, etc
#201
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
#203
CI 6,7,8,9,11 Vet
St. Jude Donor '08
#205
Well looks to me like the original build sheet is gonna be almost off limits then. Has anyone here actually removed their bumper to get their builder sheet? Sounds like quite a job.
#209
grounds, corrosion and codes
Bill thanks ever so much for the info about corrosion causing codes to appear incorrectly. That is exactly what I am experiencing lately, will check for corrosion at the ground area . great job. again the Forum comes thru!!!
#212
This thread is certainly loaded with information. If someone wouldn't mind please help me with the following listed under Secrets of the C5,
The build sheet is in the front re-bar. What is the front re-bar?
Simply remove fuse #2 under the hood and your DRLs will be out permanently What is a DRL?
Thanks in advance
Bob
Thanks in advance
Bob
#217
easy to upgrade
a corvette has all been my dream car since i was a kid. i was wondering if anyone could tell me which corvette i should get/which one would be the cheapest/easiest to make nice.
#218
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW!! Thats a tough question to answer. Its a very personal decision.
For me,,, the C5 ZO6 trips the passion button. LOVE the FRC.
There really ISN'T a which C5 is better. There all basically the same platform. The ZO6 has its HP & handling pluses but ask my wife and she will tell you the a VERT is the car for her. Any C5 can be modded to out perform a stock ZO6. The FRC is what makes it for me. Ive had a 98 coupe so Ive experienced the coupe. LOTS more luggage room and a targa top. The FRC has its OWN personality.
Find the NEWEST model car that you can find and afford in the body style that (MAKES IT FOR YOU) and purchase it and have FUN!
The best MOD that you can get is driving experience! Lean the cars driving capabilities and limitations before you get too concerned about making it faster and you will be a WHOLE LOT happier with the car.
READ THE OWNERS MANUAL cover to cover and figure out what the car offers. Use this forum for assistance before you allow money hungry dealerships to touch your car! Most often, there a simple self low or no cost fix to correct the issue.
Good luck on finding that right C5.
BC
BC
#219
turbo system
i was wondering if anyone that has any information on a good turbo system for a c5? also if you would be be willing to give me details on how much power you gained and maybe what it would cost around? that be great
#220
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Research STS & APS Turbo systems. STS is less expensive ,,,, APS is more POWER and $$$$$$$$$$$$.. BOTH are potent!
I considered STS on my 6 Coupe! Great bang for the buck!
\BC
\BC
