Base C5 GM Susp Upgrade - C6 Z51 Sway Bars - C6 Z06 Shocks - At CULTRAG Performance!
#62
Premium Supporting Vendor
You can measure the bars with a micrometer and see what you come up with and go from there. That's the best way to get started.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
#63
Everyone at CULTRAG Performance wishes you all a safe and Happy Labor Day
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
#64
Hey Gene!
I'm in Hawaii and the shipping on the bars is understandably high, I have the base suspension on a 03 vert. Are the 2013 C6 Z06 shocks still going to pair well with my stock bars or is that not a good combo?
I am definitely in need of new shocks, just trying to determine if I can go with the Z06 units now and upgrade the bars once I get back to the mainland.
#65
Hey Gene! have a question, want to upgrade my stock suspension, what i'm looking for sways and shocks that are better then my factory, i want a better ride, that is tight and smooth around curves that won't affect drivability. C6 z51 sways with c6 z06 shocks or bilstien sport shocks thanks. just want a good upgrade from stock
#66
Corvette Forum Sways and shock upgrade
Was about to order sway upgrade but I thought I would check part numbers in catalog to see what I would be getting. The front sway number you list (ending in 502) comes back as 2013 Grand sport so o problem. But the catalog says the rear bar ending in 124 is not correct for the 2013 Grand Sport. What am I missing or interpreting incorrectly?
#68
Hi Gene, You can expect a call from me for an order on Monday for my upgrade. I already purchased the Z06 shocks while piecing my upgrade for suspension together. Unfortunatly I’m new to the forum and seen your package suggestion a little too late. About an hour to be exact lol. I’ll be buying the 06 C6Z51 sways and if there is a more optimol end for them other than suggested I’ll be interested in that as well. I got parts fever at the moment on this suspension upgrade, being its my first set of goodies for my 04 base Targa I’m sparring no expense to see the most performance out of it. Talk to you Monday!
#69
i sent an email with a question. I have a 30mm Z06 sway bar on the front of my my C5 coupe. i want to install the C6 Z51 rear sway bar on my car. I need the part numbers from your sight for rear sway and polyurethane bushings if you have them
Thanks for your time.
#70
1. Front bar on my 04 measures out at C5 base. However, rear bar measures out at 17-18mm, size of a C6 base. Is this possible?
2. How do I loosen the upper bolt on the front bar end link?. It faces inward. The others are easily accessible.
#76
I've got your 2013 C6 Z06 shocks on order now for my '03 50th Anniversary, yes I've had the originals deprogrammed! Thanks for the sale price, glad I waited. Doing the Moog's also and maybe more.
