C5 Corvette Lower Front Spoiler Replacement Kit
Platinum Supporting Vendor
C5 Corvette Lower Front Spoiler Replacement Kit $94.95
These C5 Corvette Front Spoilers in urethane give your Corvette a factory-fresh appearance and restore proper air flow through your radiator, solving many cooling problems. Our C5 Corvette Front Spoilers mount in the factory locations. You can use your original hardware but if it is missing or damaged you can add a hardware kit below.
Since the front spoiler is a 3-piece design the center piece is spring-loaded and can bounce right back in place, however, the left and right sections are not, which means they could rip off altogether if you hit a bumper block or curb. A nice upgrade to alleviate this, we introduce the Corvette Spoiler Reinforcement Kit part # C5607033 (Sold Seperately). These black, ABS plastic brackets take the brunt of a bump and prevent bolts from sliding through, keeping your spoiler securely in place. Kit includes one left and one right bracket and installs easily using existing fasteners.
This spoiler kit will fit 1997-2004 C5 Corvette, including base, coupe, convertible and Z06.
http://www.rpidesigns.com/shop/item.aspx?itemid=1905
C5 Corvette Front Spoiler Reinforcement Kit $19.99
Your 3-piece spoiler's center piece is spring-loaded and can bounce right back in place, however, the left and right sections are not, which means they could rip off altogether if you hit a bumper block or curb. To alleviate this, we have the Corvette Spoiler Reinforcement Kit. These black, ABS plastic brackets take the brunt of a bump and prevent bolts from sliding through, keeping your spoiler securely in place. Kit includes one left and one right bracket and installs easily using existing fasteners.
Fitment: 1997-2004 C5 Corvette, including base coupe, convertible and Z06.
http://www.rpidesigns.com/shop/item.aspx?itemid=1908
Corvette Forum members save 5% with promo code PHIL5 at checkout
Use coupon code LANA5 to receive 5% off your order!
if these pieces are missing or damaged on your C5 Corvette they need to be replaced, the middle piece is very important to routing air into your radiator to keep your car cool. without it there or working properly your car can run hot, use coupon code RPICHRIS5 and save 5%!!!!!!
Thank you for the orders!!!
These make a great addition to any C5 Corvette!
If you would like to visit our Online Catalog for access to our entire
C5 Corvette Line of Parts and Merchandise Available for Sale,
just click the link below...
Website Link:
RPI Designs’ C5 Corvette Online Catalog
Forum Members,
Use Code
RPISHELLEY5
at Checkout for an Immediate Discount.
This Coupon Code is always Active!
