C5 Vendor for Sale Exclusive forum for vendors to list C5 products, services and promotions.
Here are a couple new products that keep unfiltered oil out & improve flow!
Old 03-16-2017, 07:44 PM
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default Here are a couple new products that keep unfiltered oil out & improve flow!
SacCityCorvette's
Precision LS Billet Barbell and other Oil System Improvement products!
The Oil Galley Barbell in your LS based engine is something that is over looked. And yet it serves a very important mission of directing oil to the oil filter. If oil leaks past the Barbell it will go unfiltered directly to the Cam Bearing, Lifters, Crank and Rod Bearings. (See Diagram Below) The factory Barbell is approximately .020” to loose so particles as big as 500 Microns can leak past the factory Barbell. Your oil filter will filter out 15 to 25 Microns depend on the brand of filter. Our 7075 Aluminum Precision Billet Barbell fits with approximately .001” clearance which will let only about 20-25 Microns pass by, that same as the filter.
Another important part is the shaft of the Barbell. The oil has to flow around it to get though the oil port. Our Billet Barbell has a 30% smaller shaft for much less flow restriction.
We have also added a 1/4-20 threaded hole in the end of our Barbell for easy removal. Just screw a 1/4-20 bolt in and pull the barbell out. No more digging and prying to get the factory one out.
Better engine protection from much less and smaller particles bypassing, smaller less restrictive shaft for better oil flow, replaceable High Temperature Viton O ring and for ease of service a threaded 1/4-20 hole.
Why would you ever put the plastic factory Barbell back in your expensive LS engine build?
See Our other Oil System Performance Improvement Products below.
Fits LS1-2-3-6-7-9-LQ4-LQ9-4.8L-5.3L-6.0L-6.2La and more! Also available for the new LT1/LT5
Only $26.95 Free Same Business Day Shipping!
http://www.saccitycorvette.com/Billet-BarBell.html
Here you can see how the unfiltered oil gets by the loose factory Barbell. Also you can see how our Barbells smaller shaft will improve oil flow!
Check Out all 4 of our Oil System Improvement products!
If you don't know much about how the Barbell works check out video.
Video of how loose the factory Barbell really is compared to our billet Barbell.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 04-14-2017, 01:41 AM
SacCityCorvette
Supporting Vendor
Replaceable High Temperature Viton O ring.
$19.95
http://www.saccitycorvette.com/BilletBypassPlug.html
Purchase these items together or separately.
Fits: GM Gen III & IV LS Engines LS1-2-3-6-7-9-LQ4-LQ9-4.8L-5.3L-6.0L-6.2L & More!
Old 09-13-2017, 05:24 PM
SacCityCorvette
Supporting Vendor
Also available for the new Gen 5 LT1/LT4!
Old 11-18-2017, 04:41 AM
SacCityCorvette
Supporting Vendor
Same Day Shipping!
Old 09-28-2019, 02:45 AM
SacCityCorvette
Supporting Vendor
If you are in the process or planning that engine build, our Billet Barbell is a must have! Small price to pay for the added engine protection!
Thank you,
Christian
To Here are a couple new products that keep unfiltered oil out & improve flow!
Quick Reply: Here are a couple new products that keep unfiltered oil out & improve flow!
