[Z06] tire strength after 2 patches
My passenger front tire has met with another nail, the second one in a year. The goodyear dealer says he can patch it (it is straight through the tread, sidewalls are ok) The tires have 10000 miles on them- should I just have him replace the tire (or both fronts)?
Oh yeah, the nail hole is straight in 90degrees perpendicular to the tread surface, not at an angle if it makes a difference, the patches will be done on the inside surface.
Patch should be done on the inside not through the tread. If the two patches are not near each other I would think it is fine. If they are close to each other I would replace the tire.
I have 4, yes 4 patches in my left rear bald Drag Radial, I live in a new development and it seems that construction workers do not like to clean up. Anyway, 4 patches and trap speeds over 120 for me....Your fine.
Oh yeah, I have one in the right front too.
Dave
Dave
Each patch or plug degrades your tire rating by one. 1 patch makes a Z rated a y. "Three patches makes the tire unfit to drive." According to my tire shop anyway.
If the patch is done properly from the inside, tread only, balances nicely, etc, etc.......well.....I've made some serious top-end charges with 2 two-holers and 1 one-holer....all on the same car at the same time, with no problems at 168 mph. So I guess I had "T" rated tires, huh!
I guess I wouldn't sweat it in the least, especially if you don't make top-end charges.
