Z06 Launch Techniques - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
C5 Z06 Discussion
General Z06 Corvette Discussion, LS6 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Closed Thread
Old 05-30-2005, 07:02 PM   #21
Ranger
CF Senior Member
Support Corvetteforum!
Ranger's Avatar
Quote:
Originally Posted by Nobigspoilerz
Ranger,
When will you be tearing up Crapitol next? I'd like to come watch.
Steve
Hey Steve, I am getting ready to sell my 02 Z06, in anticpation of the arrival of my C6 Z and I put in a fresh stock clutch for whoever will be its new owners. So I want to sell the car with zero launches. Long way of saying that I won't be racing again until the new Z arrives, hoping for August.
There is a big Corvette event at Cecil County on June 18th. I plan to go watch and would be happy to hook up there.
Ranger
Ranger is offline
Old 05-30-2005, 07:08 PM   #22
Ranger
CF Senior Member
Ranger's Avatar
Quote:
Originally Posted by MTI 427 Roadster
MAN, i tried these technique on my sticky RII Nittos and had 0 luck hooking up at the track and had horrible 60 ft times. Just need more seat time and find that sweet spot between letting out clutch and applying throttle, etc. Practice makes perfect....
The technique that works best for me is to (1) hold the launch rpm and don't move that right foot again until (2) the clutch foot is all the way out. THEN and ONLY THEN (3) progressively squeeze the throttle to the floor.
The bad 60' tend to come when the driver does (2) and (3) simultaneously rather than as TWO actions, separate but synchonized.
Just a thought.
Ranger
Ranger is offline
Old 05-30-2005, 07:13 PM   #23
Ranger
CF Senior Member
Ranger's Avatar
Quote:
Originally Posted by chiefDave
...Thanks again Ranger!....
Every day, but especially on this Memorial Day, thank you Dave for your sacrifices for freedom.
Ranger
Ranger is offline
Old 05-30-2005, 10:39 PM   #24
Dr.Ron
CF Senior Member
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Quote:
Ranger
Ron
Dr.Ron is offline
Old 06-07-2005, 11:23 PM   #25
Robert56@RNS
Collections Hold
Robert56@RNS's Avatar
Ranger, I just printed out your launch techs for the third time over a period of time. I have a couple questions on launching on the BFG Dr. Were you using the old style in the 17" size? I am picking up my 315 30 18's in the newer tread pattern and was wondering what type of burn out and starting launch might be good. I was thinking 4500 for the launch, and a medium burn out? I do have the stock clutch in good shape and no dte or hardened shaft. My first time out with the stock tires I was able to get a 1.9x with spin launching about 2500rpm. Thanks ahead for your advice and insight. Dr Ron and any others can feel welcome to give input.
Robert56@RNS is offline
Old 06-08-2005, 10:51 AM   #26
Robert56@RNS
Collections Hold
Ttt
Old 06-08-2005, 11:43 AM   #27
Ranger
CF Senior Member
Ranger's Avatar
Quote:
Originally Posted by Robert56
Ranger, ...on the BFG Dr. Were you using the old style in the 17" size? I am picking up my 315 30 18's in the newer tread pattern and was wondering what type of burn out and starting launch might be good. I was thinking 4500 for the launch, and a medium burn out? I do have the stock clutch in good shape and no dte or hardened shaft...
Hey Robert.
I used to run the BFG 315.35.17 Comp/TA, sometimes referred to as the old tread style because it's different from the newer 315.30.18s.
With that as background, the tread compound on the two types of BFG are very similar. So, I suggest 18 psi and similar launch rpms and burnout approaches to those in my write-up on launch techniques. I'd start at 3600 and adjust from there.
With new BFG DRs, I'd suggest a very strong first burnout. Then normal ones, IAW my write-up thereafter.
Good luck and let up know how it goes.
Ranger
Ranger is offline
Old 06-08-2005, 01:49 PM   #28
slow99
CF Senior Member
i notice you say "let the clutch out slowly rather than a slip". what is the difference, i always understand slipping the clutch to mean letting it out slowly? thx!
slow99 is offline
Old 06-08-2005, 02:57 PM   #29
Ranger
CF Senior Member
Ranger's Avatar
Quote:
Not sure to whom your question is addressed.
If you are asking me, I don't remember ever writing to let the clutch out "slowly." On the contrary, I suggest a fast release, with the pedal all the way out within the first 3-10 feet of forward movement.
Some drivers do slip the clutch A LOT to keep the revs high during the launch. I don't do that because I want my clutch to give a decent service life. Those that use a big-slip launch, get 30-60 passes per clutch. That's too few for my tastes.
I'd also argue that a big-slip launch (stock rwhp and clutch) gives neither a better 60' nor a better 330'. But opinions vary.
But for sure a big slip will wear out the clutch faster.
Ranger
Ranger is offline
Old 06-08-2005, 11:07 PM   #30
Dr.Ron
CF Senior Member
Dr.Ron's Avatar
I was running that exact tire on ZR1 style rims. As Ranger stated, a good 1st burnout followed by burns until you see solid smoke. Try starting at like 3500rpm's and adjust (hopefully up) depending on track prep...I'd look into a hardened OP shaft & DTE brace if you plan on running frequently on the DR's. Don't ask me how I know...
Ron
Dr.Ron is offline
Old 06-12-2005, 10:54 PM   #31
POWERTOWEIGHT
CF Member
Great post Ranger. I've come to the same basic conclusions about launching my car. I am an old street racing guy. I got my license in 1964. I use identical techniques by way of the old school of "trial and error." Your post is superb
POWERTOWEIGHT is offline
Old 06-13-2005, 07:25 AM   #32
Ranger
CF Senior Member
Ranger's Avatar
Quote:
Originally Posted by POWERTOWEIGHT
Great post Ranger....I use identical techniques by way of the old school of "trial and error."....
Thanks for your kind remarks, POWERTOWEIGHT.
Ranger
Ranger is offline
Old 12-16-2010, 07:58 PM   #33
Pretzel Man
Junior Member
nice
Pretzel Man is offline
Old 12-17-2010, 01:49 AM   #34
C5XTASY
CF Senior Member
C5XTASY's Avatar
Another thread back from the dead.
Ed
C5XTASY is offline
Old 12-17-2010, 06:42 AM   #35
Ranger
CF Senior Member
Ranger's Avatar
Quote:
Ed
If you were driving a car with an M6/M12 tranny rather than your automatic with a stall-converter, suspect you'd better appreciate why launch technique guidance is timeless and still worth reading.
Ranger
Ranger is offline
Old 12-22-2010, 05:00 PM   #36
Z06seal
CF Senior Member
Old thread, but not dead. Taking her to the track for the 1st time
she has fresh DOT 4 castrol, and a newly installed PCV oil catch can.
I still need to take the intake manifold off and clean it since this was car ran (previous owner) without an air filter and all the blowby with the dust that went through, it must be nasty in the intake. It'll give me a good idea on what the car did before and after cleaning
Hopefully these launch techniques will help! my turbo TA was auto, and the only manual I took to the track was a 03 E36 bmw, so nowhere as near the same power.
and I can't believe I'll only get like 30-60 passes on the stock clutch!?
I'll probably just do like 2-3 passes then. and then 2-3 more when the car is done with all the fixing, and that's it for this year lol
Z06seal is offline
Old 12-22-2010, 05:21 PM   #37
Grumpy
Moderator
Cruise-In 5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-10-'11-12-'13-'14-'15-'16
Grumpy's Avatar
Location: What I know, is dwarfed by what I pretend to know
Ed
Grumpy is offline
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Z06 Launch Techniques
    Closed Thread
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    It's a GREAT time to be a car guy !!! RAGGDOLL Canadian Events 2 04-13-2017 08:41 PM
    What's the definitive M7 1/4 mile technique? phantasms C7 Z06 Discussion 48 10-04-2016 05:39 PM
    [Z06] Clutch Pedal Issues—How-To Prevent and Cure Ranger C6 Corvette ZR1 & Z06 367 04-05-2016 05:29 PM
    [Z06] Video--New PR 11.02 Bone-Stock on Stock Tires Ranger C6 Corvette ZR1 & Z06 64 12-26-2010 10:03 PM
    [Z06] Bone-Stock C6Z06 on Drag Radials—New Record: 10.74 129.50 Ranger C6 Corvette ZR1 & Z06 122 01-24-2010 10:59 PM
    Tags
    automatic, c6, corvette, drag, launch, launching, luanch, radials, ranger, rpm, sale, technique, techniques, track, z06
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    Question Title:
    Description:
