Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Take Care of Your Hydraulic Clutch
Step by step instructions for do-it-yourselfers.
[Z06] Clutch Pedal Woes--Fluid Impact
I 've changed mine a couple of times and it is still dark, gonna keep doing it until its clear.
Can you mix DOT 4 with DOT 3 in the clutch system?
Ranger, thanks for all the info
FYI I tried Valvoline Supersyn DOT4 in my 2001 and found that it turned black almost immediately. Believe it reacted badly to some property in the hydraulics. I went back to Prestone DOT3 and it was fine for me.
My suggestion is to stick with a fluid that is clear or a pale color so that you can detect a color change. Super Blue Racing, is good for the brakes but is very dark blue and almost impossible to detect a color change in.
Ranger
Originally Posted by Ranger
A dealer will make $$ on your non-warranty repair. So you would expect them to advocate the replacement of all the clutch parts including the hydraulics. That is the recourse GM followed to cure the dreaded sticking pedal syndrome. But many of us avoided or cured the issue with regular changing of the fluid.
Draw out the funky fluid with a syringe like this one, available at Walmart and most auto part stores. Picture of Syringe
Ranger
Ranger
Yes, you Can mix DOT 4 with DOT 3 in the clutch system.
Ranger
Ranger
This might be why mine is turning black quickly - I'm using Valvoline as well and the clutch feels a little sticky at times, do you think this might be why?
Again. Use a clear fluid and change it when it is no longer clear. If you don't deviate from this procedure, your clutch pedal will not stick.
Ranger
Premium Supporting Vendor
Pio,
Outside of the potential issue with the fluid you are using (I used essentially clear Wilwood EXP 600 Plus brake fluid), it did take me about a half dozen changes before it started staying clean. Now I bleed mine so often that it is always clean.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
Originally Posted by Subdriver
Pio,
Only problem with the syringe is that it does NOT get the nasty junk out of the lines. It will help a "lil" bit, but most likely just discolor the new fluid from the old fluid still present in the hydraulic system. This won't be getting the grimey junk out thats down in the system by the slave....... I have seen some GRIMEY clutch fluid.
Proper flushing is a real PITA. The bleeder valve needs to be opened at the slave and force the junk out. That is what I have installed a remote bleeder in my car and a few friends have as well.. It makes flushing the entire system a 5 minute procedure.
steve
steve
steve
steve
Folks that change the clutch master cylinder/slave ought to install a remote bleeder too. Does make the full flush easier. But is not necessary for keeping the fluid fresh if you follow the syringe routine.
Ranger
I am happy to report that the blue car is back on the road after the turkey baster treatment.....(too bad it's gonna rain today, though)
Thank you again, Ranger! If I ever get work done on the cylinder I will have a bleeder installed.
Ranger
Motul 600?
Ranger, I'm curious why you didn't move to a higher temp fluid like the Motul 600 or Wilwood. Seems like this would help? Thanks for your informative posts!
John
John
#33
I just dropped my 2001 Z off at the dealership to get them to warranty the Slave Cylinder and try to get them to warranty the clutch itself, as it drags when the Slave Cylinder does not release all the way. Worst case, I will have a new Slave Cylinder (they redesigned it in 2002, I believe) and new fluid. I have been changing the resevoir for a while now (every 3k miles, since I bought the car 2 years ago). Doing this gave me peace of mind that I had good fluid, but did not help the hydraulics at all. I have had this issue for a while now. Finally brought it in to have it dealt with because the rear seals on the rear end are leaking pretty steadily...yesterday, I had little drops of rear end grease all over the rear end of my Z! I'll keep you all posted as to whether they replace the clutch under the warranty. I have the GMPP extended warranty that ends this July 5th. Need to get stuff done now!
#34
Originally Posted by jlvink66
Ranger, I'm curious why you didn't move to a higher temp fluid like the Motul 600 or Wilwood. Seems like this would help? Thanks for your informative posts!...
Haven't tried the super race brake fluids.
Ranger
#35
steve
steve
Thanks,
Steve
p.s. Any pics of the install would be greatly appreciated.
#36
Originally Posted by FasterIsBetter
Where did you get the remote bleeder set-up? I'd like to get one for my '03 Z.
Thanks,
Steve
Thanks,
Steve
#39
heat shields for clutch hydraulics
I have a 01 Z06 and have the sticking pedal problem on road tracks. I have gone through all of this thread and will put in high temp brake fluid and the bleeder valve. Super Blue has a light colored version; the following link is to a vendor of same: http://www.raceshopper.com/ate_brake_fluid.shtml
Has anyone put any type of heat shield between the exhaust system and the clutch hydraulics? If so, where and did you have to make it?
Has anyone used the exhaust/heater wrap to help keep temps away from clutch components? Did it help? Has anyone found stainless lines for the clutch system fluids?
