[Z06] has anybody else melted the rubber Boots on the brake calipers.
On may 8th I was up at watkins Glen. Had the time of my life. I bought my Z06 in mid april with 6000 miles. At the track I ran good and hard and really used the brakes. After the day the brake pads where obviously shot, about 1/8" of pad left. Towed the car there and back so no problem there. Got new pads from the dealer. When I went to replace the pads, I noticed that the rubber boots on the caliper around both pistons was melted. When I did the other side had the same thing. So all four piston rubber boots are melted. Did I do something wrong. The pads had 5/16" on them before I went to the track.(I measured them before going) I think they where stock pads. Although they only had 1 slot in them as opposed to 2 slots on replacements. I know there was a midyear pad change so I chalked-up the difference to a part change. I ran Valvoline synthetic brake fluid which I put in before the track day. Bled the whole system and all. I didn't boil the fluid at all had a very good peddle first run to last run. I hit 140 on the back straight my last run and slowed to 50 for the shikane at the 300 mark with no problem. Is this a normal track use issue? has anybody else melted these boots? Any info would be greatly appreciated.
Happened to me at Laguna Seca
Received 8,928 Likes
We will have to work on you a little. Need to be a little faster going into the bus stop at the end of the back straight. Just takes a little getting used to the higher entry speed. You probably drive through sharper turns on the street at a higher rate of speed.
Bill
It is normal. Welcome to the fun of HPDEs.
Bill
Bill
Originally Posted by 80shilling
Happened to me at Laguna Seca with my Porsche which came with awesome brakes from the factory.... I ended up having to go to bigger brakes... 14" rotors and the "Big Red" calipers. Also had to add additional cooling ducts. The 14" rotors had the chamfered slots on them, which helped cooling as well, as the slots allow the hot gas to escape from under the pad.
Hot gasses is a 40 -50 year old idea when brake pad manufatures used aspestous material in the brake pads. same the holes, any type of holes.
If your melting your melteing your brakes, yes additional cooling is needed, high temp brake pads, ( race pads not performance pads) but also a differnt braking style while driving is a good idea.
brake 25 -30 foot sooner, instead of always going extreemly deep into the corner then STOMP on your brakes. Use more momenteum then HP.
In many driving schools there are sessions when you lap with out using you brakes( emergacny use only). after a few laps the students are going almost as fast as when they did use their brakes.
Next sessions students dont use the brakes as much and lap and much faster speeds.
a past world champion Fagio was asked what was his secret to going so fast
"A little less brake, a little more throttle."
So I hate to bump an old thread, but I figure its better than starting a new one.
I found that must dust boots were completely melted off on on side's rear calipers last night, and about 95% gone on the other. I took the calipers off and was going to order a rebuild kit when I found this thread and several others like it saying that all of that was unnecessary as it would just happen again... SO:
1. Do I need to replace the "crush washers" on the brake lines before re-installing my calipers? if so would I be able to get them at auto parts stores or do I need to make a trip to the dealer
2. The pistons are definitely filthy. Do I need to pull the pistons to clean them? Once I pull them will I be able to re-install without needing a rebuild kit? what are the best methods for cleaning?
Thanks.
Thanks.
Last time I did it was with a BMW M635CSi on race tires at Sebring. Cooling ducts are your friend. New crush washers-yes. Pistons-you could try a fine Scotchbrite, but I don't know what C5 pistons are made of-if anodized aluminum-no.
Can't be done that way. Caliper needs to come off, remove pads, pry out the old seal being careful not to damage the bore, drive in new seals making sure they seat correctly both in the caliper bore and on the piston. There is usually a special tool to seat the seals, but you CAN do it with (care) an appropriate diameter socket and/or a brass drift.
thanks for your help.
I used a wrong term with 'in place', I meant with lockheed's hose in place
jm
