[Z06] Can't fit with Helmet on in 03' Z06. Help?
I am planning to buy a 03' Z06, but went to test drive it today and took my helmet with me to test the fit. I did not have enough head room w/helment on (and I played with the seat position for a LONG time). I fit fine w/o helmet, but I am getting this car for street&track use so a helmet is a must. I am 6'1" and 270lbs, so from reading other posts, I am by far not the tallest or biggest guy driving this car.
Let me put down what I have found and please let me know your thoughts on how much these mods will help, and if you've done it confirm it did yield the projected height improvement Please post any other solutions that would give me hope that I could make this work! I've read a lot of posts which discuss this topic, but do not show what people actually DID to resolve the problem. (i.e. no pics or DIY pics/instructions, or confirmation they got the intended result)
Things I found to try:
- Take 1 or 2 springs off of the OEM seat bottoms to let me sink into seat a bit further. (maybe get 1/2 inch).
- I could replace the 03' headliner with the 01' version. (~1 inch saving)
- Remove a bit of foam from seat (trade off of comfort vs. drop)
- After market seat (don't know which one, but ideas would be appreciated), bolted to fixed rail. This would be a problem since my wife could not adjust the seat if I do this which would likely kill my opportunity to get the car.
I would really need to have a minimum 2" of additional clearance to be sure I could comfortably fit in car with my helmet on (2.5 would be better). The problem on the 03' seems worse than in a friends 02' Z06, because the 03' has a ridge sticking down if you lean the seat back you don't really get relief because the roof has a step down to reduce the head room just in front of the glass. this is a bummer!
Open to ideas, I know someone on this forum must have already overcome this problem. I hope to close the deal on this car, but this is a show stopper at the moment.
Kind Regards,
Jeff
Kind Regards,
Jeff
I had the exact same problem but I am even taller, 6'5" at 260lbs, so my hair touched the headliner where it came down in the back. My first action was to replace the seats. I bought Corbeau Forza II seats in black for both pass. and driver mounted on Corbeau Slider seat brackets. That netted about an inch of head room. The next thing I did was replace the headliner with the 99-02 FRC/Z06 headliner. This was a simple mod after you get the mirrors out. That netted another inch or so as well. I still needed a bit more room so when I get to the track I take out the bottom seat cushion from the seat. The cushion has Velcro on the bottom to hold it to the seat. That got me another inch. After all is said and done I have plenty of head room with a full face Auto Racing helmet. If you are interested in the seat setup I have some pics. I think you might be able to get the room you need just by replacing the headliner and it is by far the cheapest way to obtain the room you need. I bought mine at a local dealership for about $125. I got a special deal but you can get it a little cheaper than that if you buy from Gene Cutty.
Hope that helps
Hope that helps
I have the same problem...i'm 6'2" 200...your best bet is buy an '01-'02 headliner and call it a day. No sense in tearing up your seat.
Another option is to take the stock headliner apart and remove the plastic block under the headliner that is causing you to hit your head. Aand then glue the headliner back.
Good luck
Good luck
Another option is to take the stock headliner apart and remove the plastic block under the headliner that is causing you to hit your head. And then glue the headliner back.
Good luck
Good luck
Pro Mechanic
I am 5.10.' I use a Simpson open face hemet. I have to adjust the seat a little bit. I pull the seat forward and recline it almost all the way and I have headroom to spare. Is your helmet just barely touching the ceiling or do you have to drive with your head on an angle?
I'm not sure here, but if your helmet is just barely touching, the solution could be in the brand of helmet used. Someone correct me if I'm wrong.
I'm not sure you can take the stock headliner apart like that and make it look right. The plastic pieces will come out very easily but the headliner is still formed in the shape you see when installed in the car. It is a fairly rigid material that I don't think you could reform.
A track buddy of mine did it to his 03 Z.....looks fine...i think he had a upholstry shop do it.
Thanks all for the input.
I now know that all I have to do is get rid of my Roman and German helmets and I should be fine. j/k That was pretty funny.
My height is in my torso (and butt apparently), so that drives my headroom issue. For those that said "I fit so, you should also"....ahhh Thanks but if that were true, I wouldn't have posted asking for suggestions.
electronbluec5 - I'll PM you for pics, I would really appreciate it if I could see what you have done to resolve this issue. I think, if I go with the headliner I can make this work (if not I'll take additional actions).
I have a Bieffe auto racing helmet, so it shouldn't require any further room than any other particular model.
St. Jude Donor '07
I'm a bit over 6' and don't have any problems fitting with my full face helmet on either. If I slide the seat back all of the way, then yes, my helmet will hit the headliner where it dips down. I don't race with the seat that far back though...
20003 Z by the way
20003 Z by the way
CI 3-5-6-7-8 Veteran
I'm 6'4" 250 and have no issues w/ my '01 Z w/ my g-force helmet... however riding in my father's '04 w/ the different headliner is annoying as my hair brushes on it.
Head Room
I'm 6'4' I HAVE A 2004 Z06 First change the head linner to an 01 it will get you an 1" and get red of the hump behind you head. Second i brought a manual seat track a friend of mine cut it down and got another 2 1/2" of clearence. That way you keep the stock seat. GGOD LUCK
I installed Sparco seats. Still have sliders so can adjust seat travel. The seat cushions are velcro fastened, so at the track I remove the cushions and sit on the fiberglass. For 20 minute session that is not an issue and as a result I have lots of headroom. Had some 5" thick cusions made for my wife, so we just swap out the cushions when she is driving. The Sparco seats have harness holes and side bolsters so much more restraint than in normal Z06 seats.
