[Z06] April 2010 C5 Specials @ GM Parts House
Premium Supporting Vendor
Hello All,
I’d like to take this opportunity to thank each and every one of you for a record shattering March at GM Parts House. It was my best month in business ever and it goes to show that we are the real deal here. We know our parts and we genuinely care about people, not just about making the sale. We’re here to help and you can reach us by phone, 484-949-2099, or email, gene@gmpartshouse.com or patrick@gmpartshouse.com.
Our hours are Monday through Friday 9AM to 5PM Eastern. Should you call us during those hours and you don’t get an answer, please leave a message and we will return your call. Most emails are answered within 24 hours, or less, during the week.
If you’re interested in anything at all, it is best to email or call us directly as we don’t always get a chance to visit the forum daily. Your fastest answers will come by emailing or giving us a call.
Thanks, Gene.
||--Authorized Lloyds Mats Distributor--||
We are now an authorized Lloyds Mats Distributor. Our prices are the lowest you’ll find. In fact, our prices are so low we’re not allowed to advertise them (no joke). Please contact Patrick, patrick@gmpartshouse.com, and we’ll get you a customized quote just for you. We not only sell Lloyds Mats for GM vehicles, but for all of the other vehicles. Please contact us for your price quote today!
||--Genuine GM C6 Z06 LS7 Clutch Kit--||
24248985 – LS7 Clutch
12571611 – LS7 Flywheel
Both LS7 Clutch and LS7 flywheel are 446.07 total.
For both clutch and flywheel on our website, use part number ls7clutchkit under Chevrolet make.
89059282 - LS6 Slave Cylinder – 129.19
12564455 - LS6 Master Cylinder – 131.50
14061685 – Pilot Bearing – 12.93
*Clutch does work in any LS1/LS6 drive train but must also have ls7 flywheel.
Also, can only use LS1/LS6 hydraulics.
||--Genuine GM C5 Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 134.71 shipped.
||--Genuine GM C5 Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 - sensor – 40.60 each
15234846 - nuts – 3.89 each
Total setup of 4 is 195.40 shipped
Note: The sensor comes with the washer and valve stem cap.
Setup includes: 4 sensors, 4 washers/o-rings, 4 caps and 4 nuts.
1997-2000 Sensors
25981210 - sensor – 100.78 each
Total setup of 4 is 459.71 shipped
||--Genuine GM CD/DVD Holder--||
12495014 – CD/DVD holder – 16.10
Mounts on sunvisor!
Picture here!
http://www.gmpartshouse.com/accpics/12495014.jpg
||--Helms Corvette Service Manuals--||
'97' - '10 Corvette – 149.99 shipped
Please Call For Any Other Make/Model Vehicle
To order the service manuals:
Go to http://www.gmpartshouse.com/search.html
Starting in box #1 enter part number helmsmanuals and select Chevrolet make.
In step #2 of #4 you’ll find a comments section right under the verify order button. Enter the year make and model of the vehicle in the comments section.
If you’re interested in manuals for any other GM product email us. They’re mostly all the same price so we’ll just need to check availability for you.
Contains Factory Authorized Service information written by General Motors. It contains Diagnostic Information and Procedures, Schematics and Routing Diagrams, Component Locator, Repair Instructions, Description and Operation, Specifications, and Special Tools and equipment. Service information on HVAC, Body & Accessories, Restraints, Steering, Suspension, Driveline/Axle, Brakes, Engine and Transmission/Transaxle.
||--Genuine GM 3 Piece Frt Spoiler/Air Dam--||
10401458 – Center – 83.85
10419312 – LH – 17.58
10419313 – RH – 22.13
||--Genuine GM 2010 C6 Shifter Kit--||
25823572 – C6 shifter
15851631 – C6 shift ****
11609670 - Bolt
Complete kit 190.77
For this kit on our website, use part number c6shifter under Chevrolet make.
This shifter kit works on all C5’s. The C5 boot will either need to be modified or you’ll have to purchase an aftermarket boot for a C5 that fits a C6 shifter.
Note: The Z06 shifter has been discontinued as there were problems with rattling. There are no throw or height differences as the previous difference was bushings.
||--Genuine GM Key FOBS/Transmitters--||
10253839 – 97-99 – 79.20
10432147 – 00 – 61.20
25695954 – 01-04 #1 – 66.30
25695955 – 01-04 #2 – 66.30
||--Genuine GM C5 Ignition Switch Bezel--||
2852046 – C5 Ignition Switch Bezel – 14.55
||--Genuine GM C5 Door Panel Pull Plug--||
10279471 – Door panel pull plug (rectangular shaped ebony) – 2.21
||--Genuine GM LS1/LS6 Fuel Rail Covers--||
12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering)
12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering)
Both FRC’s 69.54
12561503 - '99-'04 LH Fuel Rail Cover (Black with Red "Corvette" Lettering)
12561502 - '99-'04 RH Fuel Rail Cover (Black with Red "Corvette" Lettering)
Both FRC’s 77.50
12564257 - '01-'04 LH Fuel Rail Cover (Red With Black "Corvette" Lettering)
12564258 - '01-'04 RH Fuel Rail Cover (Red With Black "Corvette" Lettering)
Both FRC’s 114.56
||--Genuine GM Radiator Cage/Skid Plate--||
10400765 – Radiator cage – 288.76
To bolt everything to the cage you need to purchase the nut inserts below. These are threaded inserts that will allow you to bolt items to the cage. If you want to purchase new bolts you can purchase them as well.
11609836 – Nut insert – 2.83 (Qty 1)
11518908 – Nut insert – 4.60 each (Qty 7)
11570082 – Bolt – .90 (Qty 1)
11514623 – Bolt - .96 (Qty 7)
Note: Some of the hardware may show up on the website as fitting something else or another application. That is correct, they fit many other vehicles and applications.
||--Genuine GM Ultra Guard UPF 44 Oil Filters--||
25329389 - UPF 44 Oil Filter
Must order in cases of 6 @ 69.65 shipped.
||--Genuine GM Brake Rotors--||
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
Front and rear rotor sets 220.76
AC Delco Performance Drilled/Slotted
19183532 – RF rotor
19183533 – LF rotor
19183534 – RR rotor
19183535 – LR rotor
Front and rear rotor sets 282.64
||--Genuine GM 2008 C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
25819268 – Z06 Rear Shocks
Both sets of front and rear shocks (4) 246.16 total.
For the shocks on our website, use part number c6z06shocks under Chevrolet make.
The C6 Z06 shocks will work on C5’s without modification.
||--Genuine GM C6Z51 Sway Bar Kit--||
25919502 – Front stabilizer bar
10339124 – Rear stabilizer bar
10387838 (2) – Front stabilizer insulators
15241135 (2) – Rear stabilizer insulators
Complete kit front and rear is 201.25
Use part number c6z51bars on our website under Chevrolet make.
For a limited time we’re offering a free upgrade to poly bushings.
These sway bars do fit any C5 without any modifications.
This kit does not come with metal end links. If you want to add metal end links use part number 20822934 for $25.97 each.
GM has now updated all C5-C6 end links to the 2010 version.
||--Genuine GM Sport Seat Foams/Pads--||
97/98/99/00
10273418 – D/S & P/S seat back outer foam – 36.86 each
10283891 – D/S & P/S seat back insert foam – 73.58 each
10273420 – D/S & P/S seat cushion foam – 90.08 each
Complete set of 6 seat foams/pads 401.04
01/02/03/04
10273420 – D/S seat cushion foam – 90.08
88991516 – P/S seat cushion foam – 63.73
Complete set of 6 foams/pads 374.69
||--Genuine GM Tune-Up Items--||
12495519 – GMPP red spark plug wire set – 57.60
12621258 – GM AC Delco Iridium spark plugs – 6.47 each
10287788 – 97 & 98 fuel filter – 13.09
19239926 – 99 – 04 fuel filter/pressure regulator – 81.88
25042562 – 97 – 04 air filter – 11.86
||--Genuine GM C5 Belt Tensioners/Pulleys--||
12560345 – All C5 A/C Tensioner - $77.49
12557334 – All C5 A/C Idler Pulley - $39.79
12559325 – 97-00 – Serpentine Belt Tensioner - $83.36
12568181 – 01-04 – Serpentine Belt Tensioner - $68.11
12564401 – All C5 Serpentine Belt Idler Pulley - $51.57
||--Genuine GM C5 Fan Belts--||
12572188 – C5 Serpentine Belt – 52.18
19172680 – C5 a/c compressor belt – 52.64
These belts fit all C5 Corvettes from 1997-2004.
||--Genuine GM Protection Plan--||
If your car is still in factory warranty, or within 2 months and 2,000 miles of your original GMPP contract, we can assist you with a GM Protection Plan. We are providing quotes for all vehicles, including, Ford, Chrysler, etc. Please contact GM Parts House with your VIN, current mileage, and approximate miles and time you’d like to purchase a warranty for. We will customize your quote and get you details.
||--C6 Z06 Brake Upgrade Kit--||
Z06 brake upgrade kit - $1999.99 (Factory Pads)
Z06 brake upgrade kit - $1899.99 (AC Delco Pads – Please Call)
Kit includes:
Front & Rear Calipers
Front & Rear Rotors
Front & Rear Brake Pad Kits
You’ll need the proper wheels for clearance and you’ll need to purchase some aftermarket stainless steel brake lines for hooking them up. That is all you’ll need.
Use part number c6z06brakes on the website to order this kit.
||--Genuine GM C5 Front End Cover/Bra--||
19202113 – 1997-2004 Non-Z06 Front End Cover – 78.09
Z06 front end cover is no longer available.
||--Genuine GM C5 Car Cover--||
19158333 – Car Cover (Gray with black “Corvette” logo) – 229.43
This car cover is a storm shield (outdoor) deluxe car cover.
It has sealed seams and soft lining for great indoor/outdoor use.
This car cover fits all C5 models from 1997-2004. No other colors available.
||--Genuine GM Radio Surround Bezel--||
10407815 – Ebony – 199.78
||--Genuine GM Corvette Emblems--||
19207384 – 97-04 Front bumper emblem – 63.44
19207385 – 97-04 Rear bumper emblem – 41.31
10336067 – 2004 Front bumper emblem (CE) – 138.54
19207389 – 2004 Rear bumper emblem (CE) – 98.85
19207387 – 2003 Front bumper emblem (50th Anniversary) – 73.00
19207386 – 2003 Rear bumper emblem (50th Anniversary) – 73.63
10315690 – Front fender emblem (50th Anniversary) – 127.48
10429629 – Front fender emblem (Z06) – 37.73
10314089 – Front fender emblem (Z05 405HP) – 38.18
||--Genuine GM C5 Z06 Suspension Components--||
Z06 caliper set – 445.66 (all calipers total)
On our website, use part number c5z06calipers under Chevrolet make.
Z06 front screens – 193.53 (both screens total)
On our website, use part numbers 10424820 and 10424821 under Chevrolet make.
Z06 front brake ducts – 50.01 (both ducts total)
On our website, use part numbers 10295976 and 10295977 under Chevrolet make.
Z06 rear screens (scoops) – 166.64 (both scoops total)
On our website, use part numbers 10322761 and 10322762 under Chevrolet make.
Templates to cut out the rear scoops – Free!
http://www.gmpartshouse.com/template...mplate1of2.pdf
http://www.gmpartshouse.com/template...mplate2of2.pdf
Z06 rear brake ducts – 49.33 (both ducts total)
On our website, use part numbers 10425976 and 10425977 under Chevrolet make.
Z06 2004 shocks – 477.16 (all 4 shocks total)
For all 4 shocks, use part number 04z06shocks under Chevrolet make.
Z06 sway bar kit (insulators, bars and metal end links) – 318.64
On our website, use part number c5z06bars under Chevrolet make.
Z06 sway bar kit (insulators and bars only, no end links) – 226.72
On our website, use part number c5z06barsNL under Chevrolet make.
NL stands for no end links.
Z06 front brake pads – 19181427 – 133.33
Z06 rear brake pads – 12530688 – 61.20
Z06 rear differential assembly – 12572683 – 1404.27 shipped
Z06 front suspension spring – 25962573 – 261.51
Z06 rear suspension spring – 22188038 – 567.36
||--Genuine GM T1 Engine/Suspension Items--||
T1 shocks – 709.64 + 38.50 shipping
T1 trans cooler – 1069.78 + 28.50 shipping
T1 sway bar pkg with insulators and end links – 832.89 + 35.00 shipping
T1 complete suspension package – 3113.28 + 75.00 shipping
T1 suspension springs 884.74 each + 28.50 shipping each
For all T1 related items please call us for availability and to order.
||--Genuine GM LS2 Items--||
12602691 – LS2 bare block – 1135.99
89017648 – LS2 intake manifold – 319.04
12570790 – LS2 throttle body – 299.00
12633511 – LS2 fuel rails – 162.18
89017587 – LS2 injector o-rings – 30.38
||--Genuine GM Cylinder Head Bolts And Gaskets--||
12617944 – LS1/LS2/LS6 Round Port Header Gaskets – 11.56 each
12498543 – 97-01 LS1 Engine Head Gaskets (2) – 47.42
12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) – 33.70
12498545 - 97-12/03 LS1 & LS6 Engine Head Bolts – 24.96 per head
17800568 – January 2004 – present LS1/LS6/LS2 Head Bolts – 24.96 per head
12589227 – LS2 Cylinder Head Gasket – 36.86 each
If you’re not sure which bolt kit to use please email us your VIN# and we’ll tell you.
||--Genuine GM LS6 Intake Manifold--||
88894339 - Intake Manifold Only – 449.58
Intake with coolant pipe and plugs – 554.01 + 28.50 shipping.
For website ordering use part numbers:
88894339 – Intake
12602544 – Coolant Pipe
12602540 – Coolant Plug Qty 2
Online orders will show higher than 28.50 shipping.
We will adjust the shipping charge after your order is placed.
||--Genuine GM Crate Engines--||
17801268 – LS6 crate engine – 5499.99
19244097 – LS3 crate engine – 6499.99
19244098 – LS7 crate engine – 13999.99
19244099 – LS9 crate engine – 21995.00
Thanks, Gene.
2001-2004 Sensors
1997-2000 Sensors
Mounts on sunvisor!
Picture here!
11609670 - Bolt
Complete kit 190.77
Both FRC’s 69.54
Both FRC’s 77.50
Both FRC’s 114.56
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
19183532 – RF rotor
19183533 – LF rotor
19183534 – RR rotor
19183535 – LR rotor
97/98/99/00
01/02/03/04
Kit includes:
Front & Rear Rotors
88894339 – Intake
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Gene, I got my left & right lower valance panels yesterday. Thanks for the fast shipping and the great deal
These are still on backorder with GM but we do have a few sets here that are not spoken for!!! Place you order today
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
Gene,
I just wanted to thank you for the great deal I got on my C6 shifter. I saved myself huge $$$ over getting it from my local dealer. I put it in last weekend and love it, what a difference! Great customer service and prompt shipping, even going all the way to Western Canada it took only a couple of weeks from the time I ordered it until I got it.
Thanks again!
Cory
Thanks again!
Cory
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Gene
Ordered the GM Ceramic brake pads for my 2000 coupe last nignt, but I am a little confused. When I pulled up the part number as in your ad above, it gave me an option to use the "ceramicpads" part number at a price of $106 for the set of front and rears. The price listed in the ad is $134 shipped. So I am not complaining about the price reduction, trust me, I just want to make sure that what I ordered is the same as the $134 listed set and correct for my 2000. Thanks.
Bill
Bill
Gene
Bill
Bill
Yes it is the same item. We are running a sale on this special item right now. Not often there is a sale on a sale is there lol
