[Z06] Z06 Ti by-pass mod questions
Old 12-29-2012, 02:44 PM
  #101
latenightlarry
latenightlarry's Avatar
Default bypass
quinn did mine over a year ago and i have never been happier . no drone great sound best welding job ive seen in along time and...........they have gotten slightly more aggresive with more miles . perfect !
Old 06-09-2016, 12:10 PM
  #102
Georgies
Georgies's Avatar
any reason to go with 1.5" pipes? what would change if smaller diameter or larger is used?
i plan on doing the job myself so im open for ideas...
Old 06-09-2016, 12:29 PM
  #103
NosLaser
NosLaser's Avatar
My C5 Z06 with Ti Bypass exhaust, XS power long tubes, and off road X pipe:
Old 06-09-2016, 12:34 PM
  #104
NosLaser
NosLaser's Avatar
Just uploaded a quick idle vid
Old 06-09-2016, 12:44 PM
  #105
imjdoggie
imjdoggie's Avatar
I just had mine done last week sounds great but at wot I'm not too happy with the raspy sound after shifts. I used 1.75" diameter piping fwiw.
Old 06-09-2016, 03:58 PM
  #106
fisher auto
fisher auto's Avatar
As we speaking waiting on 3" X-pipe 3" back to mufflers (NO cats)..... With my cats on, down sized after X to 2.5" sounded Ok cold but was way to quite for me crusing. Hoping the full 3" will make the difference, really like the modded Ti sound...
Old 07-01-2016, 10:15 PM
  #107
John4cam
John4cam's Avatar
Originally Posted by Z06X
I anyone in the Pittsburgh area wants this done, I can help you out. I have a nice facility, plenty of TIG experience, etc. Just throwin it out there. I'm doing this to mine here shortly, so I'll have extra ti pipe.
I'm near you and I was going to have this done if you're still able to do it.
Old 07-04-2016, 09:43 AM
  #108
Georgies
Georgies's Avatar
any suggestion on how to cut the holes? Wouldn't mind some pointers before i start doing it myself...
Old 07-08-2016, 08:04 AM
  #109
DetroitPlac
DetroitPlac's Avatar
Epic thread bump, but timely. Anyone know of someone in the Detroit area that can do this?
Old 12-09-2017, 05:26 PM
  #110
dapopa9
dapopa9's Avatar
I also just had Quinn over at 74weld in San Diego weld in the exhaust mod by-pass pipes. It's not one of the best sounding exhaust systems I've ever heard at WOT with zero drone while cruising. Plus it is titanium!
I have no idea why someone would ever Downgrade and put an aftermarket stainless catback on this car.
Old 12-10-2017, 11:33 AM
  #111
Georgies
Georgies's Avatar
Can you please ask your welder what he used to cut the holes?
Old 12-12-2017, 08:16 AM
  #112
Brackets
Brackets's Avatar
Hole saw?
Old 12-12-2017, 08:21 AM
  #113
Georgies
Georgies's Avatar
I guess a hole saw would work with some good cutting fluid. Im thinking you would use a slightly smaller hole saw then the mating pipe and touch it up with a die grinder. With tig welding, you want a tight fit (no gaps)
Old 12-12-2017, 10:57 AM
  #114
KnightDriveTV
Supporting Vendor
KnightDriveTV's Avatar
Received 2,316 Likes on 990 Posts
Plasma cutter is what I use. Titanium is VERY hard to cut with an abrasive that creates heat...it hardens BIG time. Gotta cut slow and cold if you want to cut it effectively.
Old 12-13-2017, 11:24 PM
  #115
Georgies
Georgies's Avatar
Yeah i dont own a plasma cutter. I do have those carbide tipped Karnash hole saws. Gotta check if i have the right sizes. I could also check if my local tool rental shop has a small portable plasma cutter...
Thanks for the idea
Old 12-13-2017, 11:27 PM
  #116
Georgies
Georgies's Avatar
Btw, any suggestions on cup size and LPH ? Im gonna use 2% thoriated and also purge the the whole catback. Any tips woule be appreciated.
Thanks!
Old 12-14-2017, 11:33 AM
  #117
KnightDriveTV
Supporting Vendor
I mean, you're not talking about a high stress part and titanium is pretty capable of handling heat without much movement. If you're backpurging, just use the biggest shield cup you have, bump your gas output a bit and if you can pulse to keep heat low, do that as well. Run a much longer post purge as well...like double what you'd run on stainless.
Fact is, I've welded these without backpurge and welded just like I described and it didn't fail. I've also backpurged but...backpurge is setup time and money so...ya know....it depends on the risk/reward factor. It's not structural or taking any kind of stress other than heat cycling. You'll be fine.
To Z06 Ti by-pass mod questions
Old 12-21-2017, 01:37 AM
  #118
C5Z06CE
C5Z06CE's Avatar
IMO, Because it sounds better with aftermarket BB Bullet exhaust than the Ti bypass mod. Ti Bypass mod at WOT and high rpms gets a bit raspy and annoying. I appreciate that you "save weight" with Ti but an aftermarket BB Bullet exhaust gets rid of the mufflers so the weight is actually slightly LOWER with BB Bullets. My car has LG LT headers and X Pipe. I just posted these in another thread about exhaust sound but they are appropriate here too. Listen to the first 10-30 sec of each video and you will hear the difference. The 8-12-17 video is with Ti Bypass mod and the 11-19-17 video is with BB Bullets.
8-12-17 with LG LT, X Pipe, and Ti Bypass
11-19-17 with LG LT, X Pipe, and BB Bullets
Old 11-06-2018, 12:11 PM
  #119
EVLGTO
EVLGTO's Avatar
Just thought I'd bump up this thread since it's useful and been dead for 10 months. New info: The bypass mod Quinn does at 74Weld is no longer $200, he charges $300 now. I guess materials have gone up, so he charges more. My exhaust is currently at his shop getting done. Suppose to pick it up tomorrow.
Old 11-06-2018, 06:17 PM
  #120
KnightDriveTV
Supporting Vendor
I'm in LV and do the mod for anyone in the area. This is the video of the Ti "Super" mod I did. Comparison to BB bullets (weight comp, sound comp, under load, free rev, etc) in the video after 5 min mark, full build, etc.
Quick Reply: [Z06] Z06 Ti by-pass mod questions
