[Z06] What did you do to your Z06 TODAY??
#3741
Total Spring Cleaning/Waxing.
Mark.
Mark.
#3742
Thought I'd share my results of the Eibach kit for my Z
I have run it over some bumpy roads last couple days and has settled
Front bolt is all the way in( has shorter rubber ) and rear bolt was 1/4 longer than I had the Oem bolts set
( with two threads showing on Oem bolt )
Measurements are from ground to fender
Running stock z06 size PS2
Front : 26 1/4
Rear : 26 3/4
Front : 26 1/4
Rear : 26 3/4
#3743
I traded my 06 GTO 4-speed auto on Friday for an 02 Z06 in Electric Blue. The car is in good shape and was owned by an older gentleman so I don't think it was abused. But it is a bit dirty inside so I am in the middle of a seats out cleaning. I am also in the middle of removing the dash so I can get to the HUD to be able to fix it.
Update: I don't have to take apart the interior to get to the HUD. It was just set way too low. Awesome.
#3746
Front : 26 1/4
Rear : 26 3/4
Front : 26 1/4
Rear : 26 3/4
#3747
Pulled the transaxle, torque tube to address the pilot bearing and will be going thru the TT to address the input shaft damage. Also the motor mounts, and diff mount. Surprising after doing this a few times it's not all that hard.
Mark.
Mark.
#3748
Installed stainless braided brake lines and flushed the system. Use the turkey blaster method to change the clutch fluid. Discovered a broken front sway bar link so changed both those out. Adjusted the parking brakes. Changed oil and filter. Installed a CAGS delete.
Yesterday, I changed out the original valve springs to a new set of blue LS6 springs. Changed spark plugs and wires. Fixed the center console latch.
The day before that I hopefully fixed water leaks at the top corners of the doors with 3M rope caulk.
I am tired now.
I am tired now.
#3752
I used Meguiar's Ultimate Wash car soap. Then Mother's clay bar. Then Adam's 3 step polishing system from a few years ago with a Porter Cable random orbit polisher. Followed up by Meguiar's cleaner wax. I used Adam's Super VRT on all the outside trim and tires. I also used the VRT on the interior which gives a nice sheen. Really rejuvenated some of the dullness of the interior.
#3753
#3757
Supporting Vendor
Was that done at Matt's shop out by Frys Electronic at Northgate Blvd?
Christian
#3759
