[Z06] What did you do to your Z06 TODAY??
#3842
Received 1,261 Likes
got an e85 base tune loaded on my car and started it up after building another fuel system for it... still need to install my new gauges before I get the tune finalized
#3844
#3845
Finished up installing new torque tube, pilot bearing. Took some time to get the input to line up (yes I used an alignment tool) but patients paid off, the new pilot bearing/impute shaft (hole TT really) has made the Z drive like new, all the shudder from light flywheel/twin disk clutch has never been so smooth. I'm a happy camper.
Mark
Mark
#3851
Getting ready to list for sale.
Mark
Mark
#3853
Located in Truckee Ca., the history of the car has lived here on the board, 150k, alway maintain, with many of the needed extras, comes with stock parts included. No motor mods, new torque tube (old had a pilot bearing fail) Light flywheel/McLeod twin disk clutch, JRZ DA shocks, HID projector headlights,(Raidoflyer HIDs),Dewit's radiator, Cabin divider, And Custom built shifter.
Body is a 150k 9.
Int is a 9.
With shocks. $17k without $16k
Mark.
Body is a 150k 9.
Int is a 9.
Mark.
#3856
[QUOTE=Spaceme1117;1595054908]My first time doing a clutch swap on any car ever. New LS7 clutch and flywheel. Not too terribly difficult. Just takes time.
You should get an Award for doing the clutch outside in a parking lot.
I salute you sir.
Mark.
I salute you sir.
Mark.
Spaceme1117 (07-03-2017)
#3858
PWR high flow water pump, Dewitt's radiator with oil cooler, Dewitt's fans, and an Improved Racing oil cooler adapter with thermostat. Unfortunately I've hit a snag and the adapter is incorrect. Waiting on the right one so I can finish up.
#3859
Today, well yesterday now was trans and diff fluids changed for redline. MM catch can install started, but not finished. Most time there was spent building a mounting bracket. Also, PFADT trans mount/brace install.
#3860
Total clay bar, polish, waxed, vac dog hair out. (yes my dog love to ride in the Z) and removed scanner. Assembled all the stock, and aftermarket bits I have bought/used over the past 16+ years. Getting ready to go to a new home. This is almost as bad as putting down your dog..
Mark.
Mark.
