[Z06] knocking sound
Old 02-04-2012, 10:59 AM
Ashc2025
Ashc2025's Avatar
Default knocking sound
I have a noticeable knock from the front drivers side of the engine, I used my stethoscope on it and know it's not an injector or valve. It sounds like maybe a lifter, but the sound isn't RPM related. I can't get any deeper on the block because of the serpentine belt. Could be something pully related? I can't hear it on the exhaust side, only further down in between the valve cover and intake manifold.
Again, it doesn't get louder or faster with RPM, I actually can hear it once i put any load on the engine. Common issue? what you guys think?
Old 02-04-2012, 08:45 PM
Ashc2025
Ashc2025's Avatar
No thoughts from anybody?
Old 02-04-2012, 09:43 PM
mph1972
Support Corvetteforum!
mph1972's Avatar
Cruise-In VIII Veteran
St. Jude Donor '07
The LS motor has been known for some cylinder slap and it may sound similar to what you are describing, but I can't say that for sure with your situation...just not enough info.
Try posting over in TECH.
Old 02-05-2012, 09:14 AM
Ashc2025
Ashc2025's Avatar
thanks, I'll go over and check it out.
To knocking sound
Quick Reply: [Z06] knocking sound
