[Z06] >>>List of C5Z06's with failed valvesprings, not always high mileage<<<.....PICS.
#41
I did the hard work already. A properly motivated individual could now PM all the people in that list to ask for their VIN and mileage at failure. Even if only half of them respond, there might still be enough data to spot a trend.
#42
Cruise-In VII Veteran
properly motivated person? that's my life question right there.
2001-2004 owners...............SIMPLE, REPLACE VALVESPRINGS, done.
PROPER DECISION MAKING PROCESS.
#43
I've got at 2002 Z06 with 38k and stock springs no failure yet. Build is 5/02.
My questions are:
What are the part number of the GM replacement springs?
Do you also replace spark plugs and wires?
Do you also replace the valve seals?
Anything else?
I'd like to order everything at once and get the replacement going.
My questions are:
Anything else?
#44
My questions are:
Anything else?
My questions are:
Anything else?
corvetteforum.com/c5-z06-discussion/just-got-my-z-which-valve-springs-2.html
corvetteforum.com/c5-z06-discussion/10-year-vs-100k-service.html
corvetteforum.com/c5-z06-discussion/if-i-did-spring-work.html
#45
I would only be worried if I had a 2002 model year Z06, or a 2003 Z06 that was built in 2002.
#46
Conclusion was there really isn't a specific VIN range. Only conclusion was that it can happen to 2002 and 2003 model years, and the 2002s have more frequent valve spring failures than the 2003s.
Update - did some searching and found my old polls. More data for your study.
http://forums.corvetteforum.com/c5-z...ures-poll.html
http://forums.corvetteforum.com/1557697864-post9.html
#47
Wow, I had heard of valve springs being an issue....but not that many!!
I threw a couple rods in my motor fall of last year.....just now getting close to putting in an LS3. I don't have the blown motor out yet.....maybe in the next few weeks....Now I'm wondering if this might be the cause....
#48
I wouldn't say it's a "non-issue" for 2004s. In Post #29 you list a few 2004s. Valve spring failures on 2004s is much less prevalent for sure ... but not totally a 100% non-issue.
#49
my o3 Z had just over 40K miles on it. i finally dl some pics of the damage when i discovered what happened. check em out. amazing what a $10 spring can cost ya...
http://s49.photobucket.com/albums/f2...roke%20spring/
#51
I'm not confident saying anything on these cars (or any other car for that matter) is a 100% non-issue. How could one even confidently make such a claim? Freak accidents do occur. I think the numbers speak for themselves... I only found 3 reported cases each for the 01 and 04 model years, compared to 20 for the 03's, and 40+ for the 02's.
#52
Guys,
I also want to install new springs (my tuner recommends the PSI instead of the PAC´s) but I´m wondering really about his statement concerning the labor. Can you give me an understanding if this is realistic what he is writing me? I have you below his answer:
"To just change the springs out and install new ones would only take 2-3 hours. To install and shim to the correct height and tension will take 5-6 hours. We do not just change the springs, but set them up according to each individual cylinder measurement. In racing applications you need as much dynamic control for upper rpm performance, and by ensuring that each spring is assembled at the correct installed height and tension, then there will be no issues for you down the road. In full-on drag racing applications this step is absolutely crucial and as we treat every high-performance application as though it were going to the 24 hour of Lemans, this is the only way we install them."
Thanks guys, by the way, he estimates approx. $450 for 5 hours.
Let me know your thougths.
Thanks Rouven.
Thanks Rouven.
#53
You know something else to add to the list besides vin# but also ask Where a bouts was the engine rpm (if ones knows or can remember) when the failure occurred.
I still don't know yet if my engine failure was due to valve spring or not. But mine came apart at or right at the rev limiter (6500)
On a side note. Is there any legal recourse that can be taken against GM for an obvious and known problem like this? Or is this just "not enough failures" to be able to claim them at fault for a sub par component.
#54
GM never put a recall out on the valve spring failure issue ... so owners are SOL unless they had/have a warranty that will cover it.
#55
Only way GM is going to fix a valve spring failure is if the car was still under the power train warranty, or if the owner has an extended warranty that will cover the failure.
Sometimes big companies have to be forced into doing the right thing.
#56
Guys,
Thanks Rouven.
Thanks Rouven.
I did my valvesprings a few weeks ago, the whole job took about 6 hours, spaced out over a week or so.
Totally worth the piece of mind.
#57
I highly doubt any legal action by any channel is going to get anywhere now, being this issue is now 10 years old.
#59
I think this issue has been reported to the NHTSA by many people (I think there was someone on this board trying to rally a campain), and apparently the NHTSA didn't consider this serious enough to force a recall on GM. GM never "volunteered" a recall ... instead, they took their chances and covered failures that were still under warranty.
I highly doubt any legal action by any channel is going to get anywhere not being this issue is now 10 years old.
BTW i was cruising at about 45MPH, low rpms when the spring broke.
#60
Broken Valve Spring
I broke a VS (at idle) on my 03 Z06, and when it was replaced the guy saw another one that was replaced with a non-Z06 spring, so he replaced that one as well. Cylinders 3 and 7. I was planning on doing my springs this month with the Patriot double springs. I moved out to Australia and the car has been in transit getting shipped over here. Today I got it on the road finally. I think I just broke another spring. Except instead of the lucky break I got last time where the spring collapsed in on itself, this time I cannot turn over the motor. I was waiting for my electric gate to open up, sitting there at idle, when the motor started chattering and then shook really hard, and then just gave out (took less than 10 seconds). I tried to turn it over three times and it sounds like something is binding up. It doesn't seem able to make a revolution. If I just walked out to the car, I would think the starter or flywheel is having a problem, but that little shake and hiss reminded me of the other valve spring (that I drove home 400 miles on), and now the inability to crank makes me think this is a biggie. Any ideas? My car is a 03 Z06 built in August 02, VIN ends in 035105976. Can not believe I waited too long. Fingers still crossed until I pull the valve covers. Does anyone know who will ship a long block to Australia? If I have to replace the motor what else should I do while I'm in there? Clutch & PP, what other mods? BTW, I don't need any reminders of what a moron I was not to just replace them all at the time, but circumstances are what they are. Thanks in advance for any advice.
