[Z06] New Bi-xenon Headlights for C5s: GROUP BUY!
Old 04-30-2012, 11:50 AM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Default New Bi-xenon Headlights for C5s: GROUP BUY!
Exclusively from Radioflyer Innovations are the ONLY Bi-xenon projector headlights for the C5 corvette. Available in the Pop up style (modified ACA) and fixed (Stealth light cannon V2) Both use a 55w HID Bi-xenon projector that will outperform any other corvette headlights on the market.
What is Bi-xenon technology?
A projector uses a reflector, Focal lens and cutoff shield to create a pattern that is uniform and provides the maximum amount of light output furthest down the road without blinding oncoming traffic. The Cutoff shield limits light from being projected above a specific vertical mark. The result is a wide, uniform pattern that significantly increases the effectiveness of a light source over a traditional reflector.
Bi-xenon projectors have a solenoid attached to the cutoff shield that moves the shield when the high beams are activated. When the shield moves, the cutoff in the pattern moves upward providing additional light without requiring a second bulb or second filament. The movement is instantaneous and requires very little power (fraction of an amp) The result is the power of HID high beams with the uniformity of a projector and without having to wait for a second set of HID bulbs to warm-up.
Both styles of lights retain a halogen high beam for signaling purposes (you'll notice the output of the halogen high beam pales in comparison to the Bi-xenon projector in high beam mode)
Both pop up and fixed headlight kits are complete bolt-on with no permanent modifications to the car required. Both kits include all the hardware and wiring required to install. Both kits can be installed and aimed in 1-2 hours with common hand tools and can be returned to stock in less than an hour.
Stock vs. Bi-xenon projectors
SLCv2 headlights on my car:
Low beam:
High beam:
High beam (different angle) ....enough light to signal the space shuttle.
Modified ACA headlights: (output is the same as the SLC V2)
(photo curtsey of "Mr bill")
Est build time for Modified ACA lights: 2-3 weeks
Est build time for SLCV2 Lights 3-5 weeks
Pricing and ordering: (effective through Sunday May 6, 2012)
ACA complete kit (housings included) - $625
http://shop.radioflyerinnovations.co...dlights-15.htm
ACA upgrade kit (you send me your housings for modification) - $275
http://shop.radioflyerinnovations.co...cation-016.htm
SLC V2 kit - $1200 (base kit)
http://shop.radioflyerinnovations.co...lights-007.htm
For more information on the ACA pop up kit look here:
http://forums.corvetteforum.com/c5-z...flyer-gp1.html
For more information on the SLC V2 kit look here:
http://forums.corvetteforum.com/c5-g...ts-gp-3-a.html
Old 04-30-2012, 03:53 PM
Evil Oil Apologist
Evil Oil Apologist's Avatar
My Bi-xenon projectors are scheduled to arrive tomorrow. I am really stoked about getting them installed. Thanks Radio!
Old 04-30-2012, 04:18 PM
TheRadioFlyer
Supporting Vendor
anxious to hear how you like them. Feel free to post photos of your installation and finished product.
Old 04-30-2012, 05:36 PM
Evil Oil Apologist
Okey dokey on the pics. If the install guide is as detailed as the other install guides, even a casual wrencher like me should get it done on Wednesday.
Old 04-30-2012, 06:03 PM
gotz06?
gotz06?'s Avatar
No DIY kits yet For the ACA?
Old 04-30-2012, 09:33 PM
TheRadioFlyer
Supporting Vendor
At this point, I do not feel comfortable with this as a DIY modification for the average joe mostly because of the adjustments and sealing of the unit. I will continue to offer this as a modification, but I would feel best knowing that the lights were perfect when they left my shop instead of leaving a customer frustrated with a box of parts.
In my experience with the last group buy, each headlight was checked for projector-to-high-beam alignment and individually adjusted. One would think that a particular spacing would work on all the lights. This was not the case and more than likely the result of tolerances in production. I painstakingly adjusted the aim of each projector to match the elevation and transverse of the high beam often times needing different spacing from one kit to the next.
It is worth noting that one customer sent his original D1S ACA kit in for modification. This kit had the tightest tolerances of all the kits I handled and little adjustment was needed for the projector.
Old 04-30-2012, 10:12 PM
dragon84
dragon84's Avatar
bump
Old 05-01-2012, 05:24 AM
gotz06?
gotz06?'s Avatar
Ok thanks! I may just send mine to you then.
Old 05-01-2012, 11:28 AM
TheRadioFlyer
Supporting Vendor
sounds good.
Old 05-01-2012, 05:42 PM
gotz06?
gotz06?'s Avatar
Placed my order today. Email or PM me the address for shipping. I will ship them Friday Thanks, Gregg
Old 05-01-2012, 07:14 PM
Evil Oil Apologist
Gottem! They look terrific!!! Kudos.
Which installation quide from you website should I use?
Old 05-02-2012, 09:20 AM
TheRadioFlyer
Supporting Vendor
The new ACA guide should be up on the website in an hour or so. Doing the finishing touches as we speak. I don't have pictures from actually putting the lights in so if anyone wants to snap a few photos of them hooking up wiring or just general pictures, I can put those in an updated install guide later.
Old 05-03-2012, 11:20 AM
TheRadioFlyer
Supporting Vendor
ttt
Old 05-03-2012, 09:09 PM
gotz06?
gotz06?'s Avatar
Got my lights out and ready to ship tomorrow
Old 05-04-2012, 11:41 AM
Evil Oil Apologist
I'm installing mine tomorrow.
Old 05-04-2012, 03:01 PM
SJSZ06
Support Corvetteforum!
SJSZ06's Avatar
Ditto!
EDIT: oops, ran across a small glitch that will delay the installation.
I didn't know he was going to remove some connectors from the old harness
and now I have to scrounge up some parts to put them back.
In his defense he thought he was doing the right thing based on some
previous experience, but apparently my setup is a bit different.
Old 05-04-2012, 03:09 PM
gotz06?
gotz06?'s Avatar
Let us no how it goes
To New Bi-xenon Headlights for C5s: GROUP BUY!
Old 05-04-2012, 05:48 PM
gotz06?
gotz06?'s Avatar
Do you have a link to the install guide?
Old 05-04-2012, 08:16 PM
TheRadioFlyer
Supporting Vendor
use the "modified ACA" headlights guide (2nd from the bottom)
Old 05-04-2012, 09:08 PM
gotz06?
gotz06?'s Avatar
I have looked all over your site and can't find the install guide. i also did a search with no luck
Quick Reply: [Z06] New Bi-xenon Headlights for C5s: GROUP BUY!
