[Z06] ***Build Date/VIN Analysis of LS6 Valve Spring Failures***
#482
are these the correct stock replacement springs?
https://www.summitracing.com/parts/nal-12499224
Notes: GM production 2004-04 LS6 Corvette Z06 valve springs.
id wait for someone to second my vote though
#483
#486
#487
Corvettes of Auburn (a very respected shop up here) recommends replacing the Trunions also. They only use Lil John Motorsports Springs and Trunions and have never had a failure.
https://www.liljohnsmotorsports.com/
#488
However all of these vendors are using the same spring manufacturer who brand labels for each of them. Running the springs you are referring to is most likely a double spring. Again this is not really necessary unless the camshaft has been changed.
A single behive spring with the stock cam is sufficient in controlling the lightweight valves on the LS6 platform.
#489
I have been struggling to find the answer: my 2003 Z06 has bare metal or silver valve springs (no colored stripes as far as I could tell); would that mean they were replaced by a previous owner? Were all stock 03 z06 valve springs yellow in color?
VIN: 121720
Build Date: 02/03
VIN: 121720
Build Date: 02/03
#492
Good luck!
#496
2003 Z06
Vin: 1G1YY12S0351026XX
52,XXX miles. Stock except B&B exhaust
Just ATE a valve, downshifted to 3rd at about 45 on an off ramp, rev matched...no big deal...wasnt even 4,500rpm I dont think....
Never heard any bang or clanking or grinding...just got what felt like a minor misfire, car still running relatively smooth...just surging power on and off, and a put put sound (like a dead cylinder). NEVER got a check engine light. Has pending codes for MAF performance and Evap system...thats all.
This car had suffered a spring failure when brand new (first owner before I got it) and was repaired by GM under warranty.
Spring broken in half. Valve is missing, can see a hole in the piston. Only 1 of the springs on the car is bright yellow, the rest are unpainted?
I think the 1 yellow spring is what GM replaced (cheap bastards only did 1 spring??) The spring that broke is right next to that 1 yellow spring.
#497
2003 Z06
#498
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
I put an endoscope camera down my oil fill neck, and noticed that the valve springs are yellow.
It's a 2002 Z06 (in the highest risk group/danger zone based on the data) I very recently bought, with 57k miles. I read in some other threads (granted, they were very old threads from around 2007) that some of the "upgraded" springs are yellow and made in Germany and/or are Ls2 springs (ie. not all the upgraded springs are necessarily blue). Is there a way to tell, besides the color, whether the springs are stock or upgraded? Are there stampings on them (or other ways to tell) if I pull the valve covers?
#499
I swapped my stock yellow's out for blue LS2's and I have a 2002 Z06. There is no stamp, markings or anything on them just color. If I were you, I wouldn't roll the dice. I would change them out, it's really cheap and easy to swap the old ones out for stock blue LS2 springs. It made me sleep good at night knowing I could beat on it like it was originally intended for
#500
There are no stampings or other marks. Any stamping or mark would leave a material discontinuity and cause a failure point.
It would likely be best to simply swap out your existing springs for new ones. If you can do the job yourself it is super cheap.
ArmchairArchitect (08-31-2017)
