[Z06] spark plugs and spark plug wires??
What spark plugs and spark plug wires should I use in my '00 z28? Would they be the same as the ones I'd use on my 04z as well?
I'd like to retain the stock wires if I can. I've never changed spark plugs before, do you guys think I could reuse the stock wires? If not, where is the best place to buy replacement stock LS1/LS6 wires?
what about Chevrolet Performance Spark Plug Wires 12495519 ?
What gap should I use, both cars are stock and not looking to upgrade power at all.
you don't gap iridium, the delco 41-110 is a favored plug
a real OE fit, ohm, feel wire would be the denso 6718056 or delphi xs10547
not a good idea to re use 10 year old wires. they often devolop cracks when removed, can leak energy and often it's not hard to pull them apart
Pro Mechanic
Pro Mechanic
I use Denso Iridium Power in both my Z06es and my C4 ZR1, the IT-22 to be exact. Been using them for a number of years in two of those three and they've performed well and had great durability.
I use MSD Super Conductor plug wires exclusively because 1) low resistance and high-supression and 2) outstanding durability. The set I have on my 2004 has been there since 2005. Every couple of years, I take them off, inspect them and measure their resistance. So far, each time, I just put them back on.
