Forgestar Lightweight Deep Concave Rotary Forged Wheels For Your C5 Z06
#162
Can you provide the weight of both here in 18x11 and 18x12 for each wheel? I may purchase 2 sets, one for track tires/dry conditions...another set for street tires/wet track conditions.
#163
Supporting Vendor
They come out at approx: 24-25lbs
The 18x11 i do not have just yet.
__________________
Email: osvic@n4sm.com | Phone: 818-547-5474 Cell: 323-440-3532
438 W Cypress St. Glendale, CA 91204 Website: www.n4sm.com www.Project6GR.com
#164
For some reason I thought the 18 x 12 came in 22-23 lbs each and the 18 x11 21-22 lbs each...I must have confused with another wheel. I'd like to know the exact weights if you can weigh them. Thanks.
#172
Can I get some pricing info on 18 Front and 18 rear. Also pricing on 18 front and 19 rear. Also, interested on pricing differences on different finishes.
C5 Coupe I dont think that matters tho
need4speedmotors (03-18-2016)
NemesisC5 (03-21-2016)
#176
Oops, originally posted this under the wrong vendor. I bought these from Need4speed...!
Received my wheels Friday just in time to do a season opening autocross in Cam-S. Thanks Jake. I went big on rims and tires as this is a specific autocross setup. Sticks outside the fenders an inch but that was the plan.
Specs
Front: Forgestar F14 Gunmetal 18x11 +54mm with BFG Rival S 315/30/18
Rear Forgestar F14 Gunmetal 18x12 +54mm with BFG Rival S 335/30/18
Some light rubbing on inner fender by the tire under heavy cornering on rear with -1.5 deg rear camber. After first event was over I have adjusted to -0.5 deg rear camber, taken a test drive, and it seems to be clear. I have not modified the rear inner fender. The clearance on the inside is as tight as you will ever get. When the car is up on a lift with wheels free the rear wheel will interfere with the brake duct when fully extended down, but looks fine otherwise. Front camber is -2.5 deg.
Thanks KlodKrawler05 (Brad) for sharing his setup before I bought mine.
Specs
need4speedmotors (03-30-2016)
#179
