[Z06] Changing out Thermostat
I am a new Z06 owner and do not like how warm the engine runs so I am wanting to replace the thermostat w/a 160. I looked up the stat and some come w/just the thermostat and others w/the thermostat and housing as well. So, my question can I just replace the thermostat or it is best to go w/a new housing as well?
Thank you for your help
Received 1,261 Likes
you will also need to have your fan on/off temps adjusted if you want it to run cooler at idle... doing only a 160 stat will help it run cooler while cruising but the temps will still creep up at idle if you don't adjust the fans also
the fans are pretty stout... the stock fans on my c5z and old trans am were set up to run most of the time once operating temp was reached and I never had an issue... I am running spal fans now so hopefully those hold up just as good
To further your question, through 03 uses a combo T-stat and housing. The 04's use just a t-stat as it is separate from the housing. You can buy the 160° t-stat with housing from Amazon for under $20 shipped to your door. It is the same one all the vendors sell for $50 + shipping.
keep it stock. a lower temp thermostat won't help when the factory fans don't come on till 228. this engine was designed to run warm and there are no issues with it doing so
also, the housing was changed around 2004 so a new thermostat wont fit an older OE pump, all ac delco stats are now for the 04 housing. if you go aftermarket you will probably wind up paying more especially if someone still makes the old style
what you need to do is pull the radiator and clean out all the crap jammed in it. this should be done every 10-20k miles and many people neglect it. you will have a mountain of sand in the fins
13ft. lbs. I did the same this weekend. You will need to drain the fluid and it will still leak some when you pull the t-stat..
S
Before you start your job, take a good look at the radiator for grass, leaves, etc. loads of junk get sucked up into the space between the condenser and the radiator.
I just had my radiator out to replace it for a leak but I found plenty of junk right near the top.
