[Z06] C5Z tire size?
C5Z tire size?
I am sure this might be repetitive but any help would be great. I have a friend running 18in Z wheels on all 4 corners with 315/30/18 BFG rivals. No issues. I have tried looking for 2 more Alcoa wheels to make mine a square setup. Seems to be a little hard to find. What is the largest size I can run on a 17 front? 275/40/17? And can I run the 315/30/18 in the rear? Thanks for any input.
275 is good for the front. 305 35 for the back is better, not 30 series...
275/40/17's are a very common size and fit very good on our 17" stock wheels. Never heard of anyone running a 285 up front. The stock front tire was a 265 which you can hardly find anymore, which is why most just use a 275 up front these days. Im running NT-05's on my stock wheels in 275/295, they fit and look great.
Yeah having a hard time with tires. I tried finding s set of 275/295 and nothing comes up. I found a set of Falkens in 275/315. Don't know if that will mess with AH/TC though.
I went to Discount Tire and got a set of Continental Extreme Contact DWS. The fronts were originally 275/40/ZR17 and rears the stock 295/35/ZR18. After installation and driving around a bit, I noticed that the fronts appeared taller than the rears. Discount changed the fronts to 255/40/ZR17. Looks much nicer!
RW Foster (04-26-2016)
If you are also looking for wheels go to House of Wheels and ask for Bob. Google the company name. I believe he works out of Fla.
Chrome or painted....that is where I got mine and they were new and perfect match to the backs.
Good Luck.....
Fred
Good Luck.....
Fred
