[Z06] Took my '02 Z06 to the dragstrip.
#41
Hopefully yours don't keep haunting you too. The added bonus for me of going back to the stock air cleaner assembly is that I can run in the stock class at the autocross races. Even having a different air cleaner puts you into a modified class where people can have WAY more done than just a simple air filter.
#42
#43
I have to go North or South by about 30-45 minutes to find it but that's a fun commute in these cars. My problem now is trying to decide if I am going to go to the autocross or the dragstrip now that the car is running so much better. I still can't get over how great she feels now too. It's unreal.
#45
unhooking the ground resets the fuel trims. pull the ground off the battery and start from zero.
.060 gap will do it, lucky you didn't waste a coil. the GF has a mercedes with 105k on it, OE plugs, finally took out a coil. i have harped to change those for a year or more. coil died. she limped it home on 5cyl. gap was about .065. new plugs and a new coil went in, runs great.
I always gap my plugs to .040
#46
from my experience with all my ls cars I've owned Fred Meyer gas slowed my cars down. I would suggest chevron or Phillips 66
#47
oddly enough we only have 5 refineries around here and chevron owns none of them. that gas is coming from some other brand unless they truck it or ship it from elsewhere which is doubtful since 90+% of our capacity comes from those 5 and cherry point is the largest which is owned by arco/bp
#49
Great weather here in Oregon so I was hoping for some great results. The car ran 13.1 @ 111 most of the day. It felt like it was hesitating in the upper RPM range in 3rd. This became more evident when I ran a newer Mustang GT. I had him by a few mph in the 1/8th and then he had me by a few mph in the 1/4.
A run or two later the check engine light came on yielding the famous P0171 and P0174 codes. When I bought the car somebody had put a Blackwing intake on it. I'm hoping that's the cause of the issue. I should definitely be trapping higher than the 111. (I did hit a best of 13.0 @ 112.) After clearing the codes they didn't come back for the mellow drive home.
I stuck a WTB up in the parts section to see if I can find a stock air box.
Oh, and my Bridgestone Potenza's coupled with my first time back at the track in over 10 years were yielding 2.2 60' times.
I am hoping that putting a stock air box back on the car will get my mph back up where it should be and then I can just worry about my launching technique.
#50
#51
I figure compared to the life of confinement the poor car had (remember, I bought it with 86xx miles on it in January) the car is finally being used as the General intended.
#53
I still have the Blackwing on my workbench in case I decide to go ahead and use it if I ever install headers and a mid-pipe on my car. Personally though, I'm not a fan of oiled filters and would rather not use one.
#54
I'm not sure I said it would, and I don't have time to go re-read all of my old posts. What it has done was put it back to original condition to help with troubleshooting. It has also allowed me to run in the stock class for autocross, and has kept those left/right bank lean codes from recurring.
#55
****UPDATE****
I took the car back to the track today in bone stock form.
I was in the right hand lane. The left hand lane was a cam/heads/headers/exhaust/air cleaner C5 non-Z06 car. I was a tick faster than him at the 1/8th and then he somehow out MPH'd me by 4 mph both runs. I'd expect him to be faster, but I was faster for most of the run. Different red line? Different gear ratio? MN6 vs MN12? Either way, it was great fun and I'm so glad the car is more in line with my expectations now.
Here's the DA and correction.
#57
I'm just wanting to make sure I don't have a weak coil pack or some other mystery issue making itself known. I figure it's just one of those things you deal with with a car that was barely driven 500 miles a year it's whole life. Issues like this wouldn't be noticed when you're just slowly cruising to the car show and back.
#58
I highly recommend adding a catch can and another bottle of sea foam before you hit the dyno. Run that tank out with the sea foam too before you hit the rollers.
Ask me how I know lol
#59
****UPDATE****
Some more seat time with better your ET and also increase the mph a bit as well.
Proof is your timeslip. That driver in the left lane needs more practice and its affecting et as expected but mph as well. The setup could be off as well but most often in my experience driver error plays the biggest role.
Nice pass.
#60
Pulling this one back up for an update.
I took the Z06 up to Tom Wong today and he strapped it to the dyno. To make a long story short, he found that the car was going rich by almost a full point in the air/fuel about the time I thought it felt like it was struggling at higher RPM's. It looked like a stock GM tune too. Tom worked his magic and I can definitely say that any weird hesitation feeling is completely gone now and the car feels noticeably smoother all around. It even got about 27 mpg on the drive home despite a few 3rd gear blasts to test it.
I am so glad this wasn't in my imagination and there was actually something weird happening.
