[Z06] Want to install long tube headers myself...
Hi Everyone,
I have been reading and learning from the forum for a while. But, this is my first post. I have a 2001 Z06 with 26K miles. It was totally stock when I bought it. I have replaced the stock air box with a Vararam. I replaced the stock shifter with an MGW flat stick shifter. And I sent the PCM to Doug for a mail in tune. I bought a set of ARH long tube headers from CCA. I enjoy working on my vehicles and I want to install the headers myself. I would like to hear from anyone that has actually done this. How much of a PIA was it? And, how did you lift and support the car high enough to work under it???
Thanks in advance,
Joe D.
Thanks in advance,
Joe D.
The headers were on my car when I purchased it but I have had them off and on a couple of times. Mine are texas speed. Its really quite simple but a buddy of mine has a lift in his garage which makes everything a million times easier.
BulldogHD (04-19-2017)
MY LG's are on the way. Out with the terrible OBX headers and in with some decent fitting pieces. I have had the headers off the heads twice, but never out of the engine bay so I'm in the same boat.
I have contemplated doing this due to high labor cost. do any of you guys have the oil cooler adapter installed at the filter, and do the headers make access difficult or impossible to service/ tighten the AN fittings?
Iank (09-09-2017)
Banned Scam/Spammer
Received 1,319 Likes
Tech tip: use the LS1 F-body GM manifold gaskets instead of the Corvette versions as the round gaskets fit the header ports better.
Also couldn't hurt to change the front oxygen sensors instead of trying to fight the old ones off the old manifolds. Did you have the rear sensors tuned out or are you planning to run them? If you're going to run them look for the rear o2 sensor extension harnesses which you can get from Jegs or Summit. Don't forget a new catback (axle back) gaskets.
The starter wires are going to get their insulation heat cracked over time due to the longtubes. You may want to get some insulation from Jegs/Summit the same time.
Because of my work schedule, I won't be able to finish this project until Saturday. So far, I have the car up on four jack stands. I have removed the stock mid section from the manifold to the rear axle. Surprisingly, all four O2 sensors came out easily. I removed the air pipe on the driver's side. I have unbolted the air pipe on the passenger side. There's no way I can reach behind the intake to remove that last bolt. So, I'm thinking about just cutting it off since I'm not going to reconnect it. The fuel rail cover will hide it once it's all back together. Any reason why I shouldn't do that?
I still have to remove the stock exhaust manifolds. Then I will start the installation of the long tubes. The ARH kit came with O2 sensor extensions and some nice round manifold gaskets.
Thank you to everyone that has taken the time to reply. I appreciate it!
where did you purchase the headers from? did you ask for the gaskets and extentions, or did they just include them?
Thanks.
Anyone here have any experience with the pfadt headers?
http://store.afecontrol.com/afe-powe...e-c5-c6-97-13/
Thanks.
zzcop8 (04-24-2020)
I ordered the ARH headers through CCA using their link right here in the forum. They had the best price with free shipping. I'm very happy with the purchase.
The O2 sensor extensions and gaskets were included. I did not have to request them.
Good luck!
Good luck!
For me, it's not bad at all. Actually easier putting the headers (ARH) on, than it is taking the OE manifolds off (Cal smog...sigh ).
Good jack stands, +height is your friend, a lift is even better. I need about 17" minimum (rocker panel to floor).
I'll be 60 in July , if I can do it, YOU can do it
BulldogHD (04-21-2017)
Hi Everyone,
Thanks in advance,
Joe D.
Thanks in advance,
Joe D.
You need to jack up the car about 2.5 to 3 feet. Basically if you take 1 header and stand it up pointing to an 11 o'clock position, that's the clearance you need.
Drivers side slips up from the bottom and you need to jack the engine up a little. Passenger side slips down from the top.
The clamps that come with most kits are crap. Invest in 2.5" or 3" band style clamps, which ever diameter the pipes are. You'll save yourself a ton of time and aggravation.
I personally wouldn't want to attempt this without a lift. I just don't have the patience to do it on my back. Maybe you can check with a local Corvette club and see if anyone has a lift in their garage that you can rent.
I did headers myself on a G8 GT & its a PITA. I bet its a much bigger PITA no a C5 corvette too....especially w/o a lift
After you install headers you will need to get tuned, & to get the absolute most out of them (which is what you should be shooting for after dropping a couple grand on your first "major" performance mod) you should get a custom dyno/street tune.
That being said - for the price that I could get ARH headers for - on sale @ a good price from a reputable vendor, along w/ all the little supporting hardware needed (gaskets, bolts, cooler plugs/wires, O2 extensions etc) + the cost of having the car re-tuned later after I installed on my own VS. the cost of purchasing them through my local speed shop & dyno tuner (I'm lucky to have a very reputable/good shop near me), paying for them to do the install & tune all at once, it came out to me saving just under $300
I would have GLADLY paid someone $300 to install the headers on my G8 GT.
This project is finally finished! After taking a test drive, I am REALLY happy with the results. The increase in throttle response and acceleration is unbelievable. It even sounds better!
But, installing the headers on my back, under the car, with no air tools, was VERY difficult. The ARH long tubes fit perfectly and they went into place fairly easily. A lift and air tools would have made this much easier!
If you've been thinking about long tube headers, do it! The increased performance is definitely worth the effort!
