[Z06] What Size Optima to go with?
Your way over thinking this .just get an agm battery. The Amazon delco I noted above is just fine.
I have an 02Z and a 99. The 99 has a wet battery the o2 agm. When the wet battery craps out I'll buy a agm. Simple decision
QUOTE=bmarcinczyk14;1594753301]I'll ask again, will this one work for my 02 z06? According to advance it doesn't fit my car but I know some bigger sizes will work.
https://m.advanceautoparts.com/p/autocraft-platinum-agm-battery-group-size-78-740-cca-78-agm/10310751-P[/QUOTE]
I have some people telling me the Advance gold I just purchased will be fine and others saying I should exchange it right away with an AGM. Which is it? And again, will this size work with my 2002 Z06 if I do decide to exchange it?
https://shop.advanceautoparts.com/p/...agm/10310751-P
Regarding whether the other battery will fit? I don't know. Look up it's dimensions. Compare those dimensions to your battery tray and give it a shot. I doubt you're going to find anybody else who is running a specific generic battery from one of the parts houses who happens to read this.
If your current battery is mounted solidly and your battery cables are tight, get out there and drive the car!
What car do you have? As far as whether the battery will fit, if the 2001-2003 c5's have the same size battery tray and clearance in the area as the pre 2001 c5's it should fit no problem since that 78 series is what the pre 2001 vettes used. For some reason GM decided to use a smaller 75 series battery from 2001 and on.
Nice, exact same year and color as mine. Damn and I thought my 28k miles were low! Have you checked if there were any signs of your non-agm battery leaking? Do you know how old the battery is?
Have the valve springs on your car been replaced yet?
#33
Think I'm just gonna stay with the conventional lead battery I just got. Chances of it leaking are pretty slim with the newer ones, from my understanding the issue mainly lies with the original own a.c. delcos
#35
https://www.corvetteforum.com/forums...-failures.html
I did mine before I took it to any races just to be safe.
#37
My car was built early 2002. It had the yellow valve springs. That was more than enough reason for me to replace them. I don't want to be nervous every time I drive it that I might drop a valve.
#38
So yellow spings=bad? What's the last 5 of your VIN? Mine is 05359. I believe built either August or September 2001. Would mine have the yellow springs?
#39
Only way to know for sure is to look at them. You MIGHT be able to see if you shine a light into your oil fill, but you may need to pull a valve cover if that doesn't work.
