[Z06] How to remove oil fill neck?
I want to see what color are my valve springs are. How does the oil fill neck come out? Just pull/pry up or does it twist out? I don't want to break it.
Banned Scam/Spammer
Received 1,319 Likes
You have to remove the valve cover and pull on a tab from the inside with a pick. It's a pain in the *** and most likely wont cooperate. A new neck costs $7.50 from NAPA. When I needed to remove it once for polishing I used a ******* hammer. Then twisted on a new neck afterwards.
If you want to check your valve springs you'll be removing your valve cover regardless.
I tried and tried and tried, but couldn't get the damn thing off. Even with a pick set with a crazy 2 bend tip I couldn't coerce the tab to unclick itself.
If you've got a scope with a light on it that would help. But I found it easiest to just take the whole damn valve cover off and check them all. You can literally take it off in under 5 minutes. Might seem like a lot but it really isn't. Just unscrew the coil plate and then you're about 4 bolts away from getting the valve cover off.
I've had mine on and off a few times and never replaced the original VC gaskets and never had any issues. They are an O-ring style, they are easily reused unlike the old school sbc gaskets.
