[Z06] Heard/saw a new Shelby GT350 this morning
Old 06-22-2017, 08:23 AM
NosLaser
NosLaser's Avatar
Originally Posted by Quickshift_C5
Not at all, I've owned two of them. I'd argue that the GT350 doesn't sound like any other Mustang. Odd, since most Mustangs sound absolutely amazing with very little work, if any.
Hey, figured I'd cover all bases
Old 06-22-2017, 01:49 PM
Z0SIS
Z0SIS's Avatar
I think I must be the only one on the planet that doesn't like how this car sounds.
I personally think the 5.0 Coyote sounds better.
Old 06-26-2017, 12:08 PM
WannaC5Z
WannaC5Z's Avatar
Yeah but it depends which exhaust you have on them. Mine came with Flowmaster Outlaws and they were way too loud with a horrible drone on the highway. I went to Magnaflows which were only loud at WOT. I would have preferred Corsas but I found an incredible sale on the Magnaflows.
Old 06-26-2017, 01:43 PM
dbgoodwin
dbgoodwin's Avatar
You aren't. I've only heard one out of maybe 10 that I thought sounded pretty good. The regular 5.0 sounds better, even a 2 valve 4.6 sounds better.
Old 07-02-2017, 01:40 PM
c5arlen
c5arlen's Avatar
Originally Posted by ArmchairArchitect
A marvel of engineering. The flat plane crank makes it sound like a true exotic car, and lets it rev super high.
Please... What's a flat plane crank and what is the reason for sound?
Old 07-07-2017, 11:07 AM
WannaC5Z
WannaC5Z's Avatar
But the real reason we’re excited about Ford’s new 5.2 V-8 is its lightweight, flat-plane crankshaft, a unique setup for a relatively plebeian road car and one that makes the GT350’s V-8 the largest displacement of its type. The piston’s connecting rods in conventional, cross-plane V-8s attach to the crankshaft at 90-degree intervals, but a flat-plane V-8’s attachments are at 180 degrees, thereby separating the exhaust pulses of each bank of cylinders and improving overall breathing—the key to making power. With proper development, it also allows the engine to rev higher (the GT350’s redline is a lofty 8250 rpm), while generating a hellacious wail of an exhaust note. CAR AND DRIVER
Old 07-07-2017, 11:44 AM
TrackAire
TrackAire's Avatar
Apparently they are going to push the envelope with some forced induction to keep up with the ZL1's of the world:
https://www.sema.org/sema-enews/2017...campaign=eNews
Old 07-07-2017, 12:23 PM
KnightDriveTV
Supporting Vendor
KnightDriveTV's Avatar
Received 2,309 Likes on 988 Posts
Interestingly the GT350R BARELY lost to the ZL1 at Willow Springs on Motor Trend. Shows the GT350R has a definite bit of savvy to make up for a horsepower deficit. ZL1 1LE will certainly be a different story, and likely more "apples to apples" but when turns are involved, GT350R can certainly hang with a high power car if the driver is capable.
Most here, I assume, are talking about straight line which is fairly irrelevant to this car as it wasn't built for that. Seems quick enough to wreck coming out of cars and coffee like all the others.
Old 07-07-2017, 03:10 PM
Alexander K
Alexander K's Avatar
The gt350 is a disappointment imo. The crank is u-d-u-d configuration requiring large counter balances at the ends, mitigating the pros of a lighter cranks. To top it off they used one intake manifold mitigating the pros again of having a flat plane crank by using a separate manifold for each cylinder bank. The voodoo has a high rpm due to a great top end and cnc'd heads. Nothing to do with the flat plane. The voodoo also doesn't very large increases in power. The flat plane does sound very unique and interersting so ill give it that.
The cars performance is also lackluster. A c5z with equal tires will keep up. Full exhaust and intake would edge out the 350. T1 or coil overs and even the 350r would be no contest.
ArmchairArchitect (07-08-2017)
Old 07-08-2017, 10:39 PM
Slick61
Slick61's Avatar
I've been a Ford and Mustang guy most all of my life. I've owned an '85 GT, '97 Cobra, and '14 GT. Loved all three of them BUT...I had an '01 Z06 prior to the '14 GT and a year later bought my current '03 Z06. Sooo you can tell which one impressed me more. Plus the '14 model is 100lbs lighter than the '15+ models so they are a tenth faster in the quarter mile. I can attest that my '03 would kill my former '14 GT after 50mph. Up to that it would be a driver's race IMHO. Now the Shelby GT350 is another story. Yes heavy but my gawd it looks and sounds incredible. I'd trade my C5Z in a heart beat for one if no car loan required. LOL
I hear ya... I had an '86 GT, and '01 GT, and an '05 GT... all 'verts. Loved the '86 the most (and currently looking at another), but my '04 Z06 is a completely different animal.
Old 07-09-2017, 04:33 PM
WannaC5Z
WannaC5Z's Avatar
I have to respectfully disagree with you. I think the heavier GT350 still takes the modded C5Z on a road course. It was simply built for that purpose and is a superbly balanced car. I own a 2003 C5Z but would trade in a heartbeat for a GT350 if someone offered. I've never heard a Corvette sound as good as any Mustang with a decent exhaust...5.0 pushrod, 4.6 dual cam, 4.6 quad cam, 5.0 quad cam, or the GT350.
sublime1996525 (07-14-2017)
Old 07-10-2017, 01:00 PM
oharal
oharal's Avatar
I drove one last year at a Ford event at AMP for 3 laps with a Ford Racing school instructor. It was quick but they made us stick it in 3rd and leave it (lame). It sounds amazing and handles its weight quite well (something around 3800lbs :O ). Can't afford it but even if I could it wouldn't push my 02 Z06 out of the garage.
Old 07-10-2017, 08:10 PM
  #33
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
defintely..they are a handlin ****
Old 07-14-2017, 12:14 PM
  #34
sublime1996525
sublime1996525's Avatar
I have a GT350 and this car is a beast on a road course. It is not a straight line performer and that's not what it was built for. Taking the car all the way up to the 8250 rpm redline, braking hard - the brakes are fantastic, turning into a corner at a much higher speed than you thought possible, and flying out of the corner with the car planted and ready for the next one is what this car is about.
I had a H/C/I C5Z and a C6Z and this car is a different animal. It's not as fast in a straight line but I believe it would out perform either of my Z06's on a road course. All are great cars and it's an awesome time to be a car guy!
I also giggle like a child every time I drive this car. It's a smiles per miles car for sure!
Old 07-14-2017, 12:52 PM
  #35
JeremyGSU
JeremyGSU's Avatar
A stock C5 Z vs 350R the 350 would win no problem I think. I mean the 350R barely lost to a ZL1 at Buttonwillow and I don't think a stock C5 Z would be anywhere near a Zl1. The C5 brakes just aren't up to the task on larger road courses. Mod the C5 enough then sure, but that's not exactly apples to apples versus a stock street car.
Old 07-14-2017, 01:13 PM
  #36
dbgoodwin
dbgoodwin's Avatar
To me it's hilarious how people rave about the GT350, yet half those people also prefer the new M3/M4 to the older V8 M3 because it makes easier to use power.
I guess I just feel like most of the people think it's so special just because they were told that it was so special. There isn't anything revolutionary about the car, it's wicked fast, and cool, but it isn't anything that hasn't been done before.
A high revving N/A V8 is soooooooo revolutionary. GM has done it with the LS6 and LS7 (though less RPM) BMW has done it, ferrari and lamborghini have done it, lotus has done it, lexus has done it, audi has done it. Hell, even ford themselves have made a few high RPM v8's such as the SHO 3.4 where people have reported spinning them up to 7700-8000 rpms before.
The flat plane crank has been done before, it's nothing new.
I'm a huge fan of NA power, and I quite like the GT350, but it's by no means revolutionary.
Quick Reply: [Z06] Heard/saw a new Shelby GT350 this morning
