Codes
Codes
Sorry to ask a stupid question, but being an absolute newbie, I have to ask 'What are codes'? And where do I find them.
I changed the tips on my 2001 c5 oem exhausts & got a Check Engine Light (CEL?), which I realize was because I effected the emission system. But that that went off on it's own. As did the "service tire pres. sys" light.I checked the pressure in all 4 tires & found a leakey valve stem which I adjusted.
Are these what you are referring to as 'codes'?
And lastly, do I need to do anything about the CEL warning.
thks.
thks.
Here is a video that will help you look at and clear codes.
I would suggest reading the "stickies" at the top of this page and the Tech section. Great information to learn about your car.
Saltywheels (10-30-2016)
This has been a great education. Thks all for jumping in so promptly. The OBD site is hit & miss. can't always get a response. Got lucky with 2 of the 5 codes thrown, as follows:
10-PCM: P0171 H System too lean Powertrain
P1431 H ditto
38-RTD: B2795H ??
99-HVAC: B0367H ??
B0-RFA: C2115H ??
Since I am having trouble getting Obd2 to respond to the last 3 codes, they remain a mystery for now. Will keep trying.
P1431 H ditto
38-RTD: B2795H ??
99-HVAC: B0367H ??
B0-RFA: C2115H ??
Good luck... GUSTO
jdvann (10-31-2016)
Got some codes...
Hi all,
I just learned how to access and clear the codes...
This C5 is new to me and most of the codes I tried entering in the OBD code look-up, but no info was provided.
Here are all the codes that showed-up...
28-TCS:
C1295 H
AO-LDCM:
B2282 H
B2286 H
B2284 H
U1096 H
AI-RDCM:
B2283 H
B2287 H
B2285 H
U1064 H
U1096 H
10 PCM:
P0101 H
P0171 H
*I saw the ones that had to do with the mass-air flow and lean mixture. I saw that after I returned to New Mexico after driving the car back from Cali where I picked it up, the intake was really loose (Short Ram) and the CEL was on. After I tightened everything up...the CEL went away, so I am thinking that problem was solved.
As far as the other codes, I would appreciate if someone could share the translation and if there is anything I need to worry about?
Thank you so much!
Liam
28-TCS:
C1295 H
AO-LDCM:
B2282 H
B2286 H
B2284 H
U1096 H
AI-RDCM:
B2283 H
B2287 H
B2285 H
U1064 H
U1096 H
10 PCM:
P0101 H
P0171 H
Thank you so much!
Liam
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Hi all,
28-TCS:
C1295 H
AO-LDCM:
B2282 H
B2286 H
B2284 H
U1096 H
AI-RDCM:
B2283 H
B2287 H
B2285 H
U1064 H
U1096 H
10 PCM:
P0101 H
P0171 H
Thank you so much!
Liam
28-TCS:
C1295 H
AO-LDCM:
B2282 H
B2286 H
B2284 H
U1096 H
AI-RDCM:
B2283 H
B2287 H
B2285 H
U1064 H
U1096 H
10 PCM:
P0101 H
P0171 H
Thank you so much!
Liam
The following 2 users liked this post by laurent_zo6:
IrishViking505 (07-14-2017),
Mayor111 (07-14-2017)
So, I cleared all the codes yesterday.
After driving to work today, the "Service Traction Control" code popped up.
Code C1295 = BRAKE LAMP SWITCH CIRCUIT OPEN
*What would this be and how do I correct it?
Thank you for your help!
Liam
Liam
