[Z06] Transmission vibration issue
Ever since I had my clutch done there's been vibration from the transmission. I was told I needed to have my aftermarket flywheel balanced the same way my stock one was but every machine shop says it's impossible. Any advice?? I live in the Houston area
So what did you actually get done? Got your clutch changed. Straight out of the box, any "balancing", new flywheel and pressure plate, resurfaced flywheel, any other new parts, what did you have done?
I feel your pain. Last week at McDonald's, I tried giving the cashier 15 cents extra so I could get back a whole dollar amount of change. She hadn't punched it in the computer that way and already had different change in hand. Told me she couldn't do it, it was "impossible". Man, was I disappointed. Here I thought it was just basic math, guess I was wrong.
Having a machine shop tell you match balancing is "impossible" is like a cashier saying it's impossible to make change in any other manner other than what the magic computer tells them. They know how to push buttons, but they don't understand the math behind it. Maybe Monster just knows how to do the impossible!
Good luck, I think you are on the right path.
That's very good. Monster understands the balance issues. That's great they are offering to match your original setup. Hopefully that takes care of it. If it doesn't, then something else is going on.
Is that balanced as an assembly with clutch disk and pressure plate? Or just the flywheels?
After typing that I had a duh moment about the clutch disk part. lol
I have read about people with vibrations after dampener replacement. The service manual actually states something like if the factory balancer has been weighted that the new one must be weighted to match.
Possibly. Apparently the GM balancers are known for going bad and actually coming apart. I guess they can separate and either go forward into the rack or backward into the timing cover. I've read that you can sometimes see them wobble when the engine is running. Everyone says to run the Powerbond balancer or a performance aftermarket unit over the GM replacement.
