[Z06] Wind noise from driver-side window at speed
Hi all,
Replaced my DS power window assembly on my '03 C5Z and have introduced leakage (noise) at highway speed. Window height is adjusted back to where it has always been, but it seems I need to tilt the top of the window in towards the weather-stripping. Is there an adjustment to accomplish this, shimming or something? I believe a small amount of tilt would do the job. Would appreciate any tips. Thanks much.
There is an adjustment that allows you to tip the window in or out at top just a little, google c5 window adjustment should produce all the info and video you need.
