[Z06] C5 P0704 Clutch Switch Input Circuit Code...
Its car inspection time!!! and just as a precaution i decided to plug in my code reader and what do you know... P0704.
I unscrewed the panel to see if my switch got loose but it looks good to me, the clutch pedal is touching the sensor when its out... what do you think it could be?? maybe a faulty clutch sensor??
Banned Scam/Spammer
Received 1,319 Likes
Logically thinking, if it isn't the switch itself then its in the harness or onwards it would be the ECM itself.
The clutch switch is the easiest to replace/rule out.
RomanNYC (09-11-2017)
nvm found it. if anyone needs vettenuts has them. http://www.vettenuts.net/index.php?l...t_detail&p=125
