[Z06] Air filter intake, mass air flow code
Got code on my 2007 Z06, mass air flow error. Took off air filter/mass air flow housing and see glued in upper and lower heavy paper liners in the tunnel. The lower paper is separating from the plastic housing, lifting up into the intake air stream, and I think disrupting the air flow past the MAFS. What is the purpose of the paper inserts? Can I remove them or should I try to glue them bac to the plastic?
