[Z06] Headers and tune
If doing headers, I highly suggest getting them ceramic coated. Ram Pro Line up off of Craig Rd does an amazing job. Paid $350 to get my headers coated. It'll drastically reduce your under hood temps. Living out here (plus I work in the automotive cooling industry) I see what heat does to cars every single day. PM me if you want Frank's info, very knowledgeable guys and takes his time with tunes without short cuts. Also has great reviews all over the internet.
How about $149 then? I do several of these tunes per day, feel free to take a look at our mail order tuning thread.
https://www.corvetteforum.com/forums...nly-149-a.html
DOUG @ ECS (09-14-2017)
3 years ago by memory:
TSP headers = $500 + freight
CAI (used) = around $150
X = $100 (Magnaflow)
Cats = $200 (Magnaflow metal)
TSP tune = $150
Labor to fit X to existing mid section = around $200? (if I were to do again I'd buy a complete mid with cats)
Labor to install = free; me
TSP tune = $150
Think I'm paying $550, I'm having a lot of other work being done right now too - headers, 3" x pipe, valve springs, water pump, etc. You have to look at the cost involved when paying for a dyno tune vs. a mail order tune. Tuners have rent to pay, utilities, cost of a dyno and much more hence why their prices are higher. Not to knock any mail order tunes as I've seen great tunes here on the forums from Chuck @ Cow and others as well. I just want my car dialed in 100% and don't mind spending a few hundred extra to get that piece of mind and also be able to consult with someone local if something happens to the car.
Still learning her and blown by her just at stock levels. Exhilarating!!!
Kooks is a premium brand, but the latest TSP and XSP seem to be problem free. The X was just that, just an X. I cut apart my factory mid section to install it.
If so... Which one is the correct one of these 4 I attached?
There are plenty of good options for cats. My research told me metallic were the best option, and Magnaflow among others were a good option. This is what I bought:
3" thru, they are mounted almost immediately after my header collectors, into a modified X:
...which was welded into the rear half (cut off and discarded the front half) of the factory mid section.
I can snap a pic somehow if curious.
Thought X pipe is larger usually. I guess this was a universal part, hence didn't fit perfectly.
I have a mail order tune from Diablew Tune (http://www.diablewtune.com/). He sells the Diablow inTune programmer and does a remote tune based on logs that you collect and e-mail back to him. He has a reputation for being able to do remote tunes that are nearly as good as most shops dyno tunes. He also includes 1 year of free updates so if you add other mods he will adjust the tune for free. $510 (tune plus programmer).
As for the intake, I am using the stock intake with the Zip Tie mod and K&N filter with a better sealing, and higher flowing air bridge. The Zip Tie mod will get you 80 to 90% the benefit of an aftermarket intake for a fraction of the cost.
I will add my 2 cents. I have the Texas Speed headers and catted connection pipes connected to the stock Ti Z06 exhaust. I would argue these headers and pipes are just as good quality as Kooks, ARH, etc. for half the price. $1000
Yup. I'd do the CAI with tune if going that route.
#33
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Call me on Tuesday......
914-332-0049
Chuck CoW
#35
