Removed Clear Bra and now have cuts in paint!
The general rule of thumb is that if your fingernail can catch the scratch, then it is too deep to sand out. In addition, remember that by sanding you are removing the thickness of the clearcoat and decreasing the protection it provides.
TEAShea
from Nebraska
TEAShea
from Nebraska
Originally Posted by EHS
Clear bras are not available pre-cut.
They are cut to a pattern, but there is always some cutting involved.
Visit Xpel's site to see all the kits that are precut and available for just about every current model. Any installer that knows what they're doing will not have to do any further cutting to the precut kit. The guy that did my car simply applied the kit without any additional trimming or cutting. Always make sure that your installer either uses precut kits or does not do any trimming directly on the car.
http://www.xpel.com/products/tools.asp
Olfa Razor Knife Part Number: P9906 Price: $14.95
If you want the thing to look right, you need to trim at some point.
From the site link you provided above (under "installation tools" that they sell):
Oh yes, the blade, there is a reason they sell bulk film on that site, so if you want to make a custom piece you can trim it yourself.
Worst case on this (as long as the cuts are within the clear coat and not down to the base/color coat) would be to need to CAREFULLY hand sand back the cuts, then spray new clear coat. Then color sanding and buffing would make it pretty again.
A high end body shop can do this without any problem.
Good luck. I now know never to consider this product.
Get that repaired and get a Speed Lingerie Bra with optional license plate holder.
if that is an issue in your state, problem solved in fact the Speed Lingerie Bra will solve a few problems.
I'm not sure who you were dealing with but the whole idea of the precut kit is that it's ready to be applied without trimming..
Just my .015 cents.
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
Originally Posted by Rob4092xx
My scratches are very thin and light.
How deep were yours that required repainting?
I would not let this stop me from using the clear shield. We got a nasty rock chip in the front of our Tahoe 2 days before we took it to "the slasher" for clear shield. The one silver lining in this whole thing is that since they had to repaint the front of the hood, the rock chip is gone. I would just be very careful about who I lest install it. We just pickud up our Tahoe and the guy did a great job. And to those that take (false) comfort in the "mine was pre-cut" - the jagoff that cut our paint used "laser cut" pieces too. But as I said in my first post, it often gets stretched as the apply it, and has to be trimmed. That's why a utility knife was on that website. I can't provide any better evidence than that.
St. Jude Donor '05
Oh no. That sucks! I just received my GM bra, strictly for use back home from BG and I am very worried that similiar damage my happen to my car.
#33
1 Post
EHS, I believe that the clear bra detracts from the looks of the vehicle...I remember seeing the Nissan 350Zs at the dealership with the clear bra on them...they are so noticeable...not for me. I'll take my chances with chips,etc., and if need be...a fresh coat of paint!
#34
wow that sucks man...
For the clear bra haters out there the install is key, when a top notch pre-cut kit is properly installed there is NO TRIMMING. Most that sell kits, also sell bulk, that is what the knife is for...
When looking to have a clear bra install DO NOT go with the cheapest price, this is a service and you get what you pay for most of the time. If possible have the dealer install it. Chances are if your dealer offers it they sell a lot of it and do a top notch job - plus they will stand behind it.
In any case, best of luck with you situation!
#35
That's too bad about the cut marks in your paint, a rookie mistake for sure. Pre-cut kits are the only way to go, I totally agree with WWW.
This product works great. Finding a good installer that can apply the film where it is almost invisible can be tough.
http://www.speedfilm.net/photos_corvette1.html
#36
CI 1-4-5-8-9-10 Vet
I will repeat myself ..... AGAIN. When our paint got the slice-n-dice treatment, the installer was using a PRE CUT KIT. Do not be lulled into a false sense of security. This product often (but not always) stretches as they apply it - rub it on. That is why it often has to be trimmed at the edges. I would bet money that everyone that has their paint cut was having a "laser pre-cut" kit put on, just like us.
#37
If you're using a novice installer that's what you may end up with. Even if the kit is precut, they may not have enough experience to properly stretch the film. I watched the guy that did my car and he did not have to cut anything. All the edges aligned properly, there were no bubbles or any other BS. For best results, visit either the Xpel site or 3M site, both have a list of factory-trained installers. (that's where I found mine.)
#38
#39
CI 1-4-5-8-9-10 Vet
Our chevy dealer used Lumar on our Tahoe and it looks great. If you didn't know it was on the car, you would not even notice it unless you were within 6 feet.
#40
I'm still on the fence with this one. I would rather have chips than a clear bra and cuts in the paint, but even if you allow your car to get chips and get it repainted the new paint is more likely to chip than the factory paint. If you use the car for weekend track events, protecting the paint becomes even more of an issue. What to do?
