05/06 build quality?
As an 05 c6 owner, after closely inspecting an 06, i've noticed the build quality is not as good. carpet issues in the back & paint on underside of deck lid not finished. Also carpet was scored on the side of the trunk for a cut out that was never done.
Has anyone else noticed this drop in quality? perhaps this is an exceptional case.
I have been over my entire car (06 vert) very carefully after driving back from NCM. I really can find no faults in quality of build at all. Hopefully your's is an isolated case. I was impressed during the factory tour at the efforts that went into quality assurance.
I am a perfectionist, and I am quick to recognize any deficiencies...I am more likely to complain to everyone that will listen, rather than try to conceal such faults. My 2006 has some minor problems...for example, the paint has too much orange peel. It's the nature of modern finishes...it's caused by low VOC, high solids clears...BMWs, Porsches, etc. also have it, but for some reason, it seems to vary from car to car. The front fascia also has an almost imperceptible bulge on the right side, and I have discussed it here.
Overall, however, I am impressed with the build quality: Body panel gaps are uniform, and closer than in the past; flexible fascias fit well without distortion compared to past models; paint color and metallic content matches very well from panel to panel including the flexible fascias; overall exterior trim fit is good. Interior fit and finish is good; that's not to say the interior is as nice as the most expensive cars, but GM successfully executed what they intended.
You have to understand that in mass produced cars, underside surfaces like the deck lid are not finished to exterior standards, and carpet may be perforated for cuts that are not required in all cars because of options. I don't know if that is what you are seeing, but I'm sure they would typically try to conceal it. These cars are really ALL different at the micro level.
That's my experience owning both and giving both a in-depth inspection.
the paint on my deck underside is not finished. i wiped it down yesterday and it just came off
delayed, whipped around, priced gouged, and told quality was good, Ive got to go the the Lexus......after the drive and the dealership and treatment, and class....there is a substitute for the Vette, Lexus
I've had my '06 for a week now and I'm very pleased with the build quality. The paint looks very good, with less orange peel than I had on my prior 2 BMW's. The interior is also well done, with good fit and finish. I'm happy with the whole package!
