Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Change Your Oil and Oil Filter
Step by step instructions for do-it-yourselfers.
DIY Oil Change - update -
#81
Received 3,981 Likes
car lift
Well there is that or get a 4 post car lift.
I am lucky enough to have a car lift that my c6 and my SRT8 Jeep Grand Cherokee swap places for depending on the weather...the secondary benefit is oil changes are a snap.
www.backyardbuddy.com
#83
What size is the oil filter wrench and where did you get it?
Will this work:
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Seems like overkill to get the whole set, though.
Will this work:
#84
c6 oil change
if you look under the car , the drain plug and filter are on the drivers side of the engine . I jack up the passenger side to get all of the oil out ...
#86
Oil Filters: Some of the motorcycle guys have found Fram's to be "lacking", K&N's were okay, Mobile 1 is better still is Pur 1, for the LS-3 and LS7 its PL12222. Wix is on par with Pur-1. One very noticeable point is the amount of filter paper enclosed. The filters were cut open and the paper laid out side by side, Pur-1 had the most.
As for mileage, my Denali has an oil sensor installed in it too, giving you an idea when the oil is ready to be changed. For me, when it gets to the 50% level I'll change it (or have it changed by a dealer I trust). I won't use the cut-rate outlets. They seem to have trouble remembering to tighten certain oil drain bolts that can wreak havoc with engines, differentials and transfer cases (as the case may be).
#87
I wonder what the concensus would be on oil filters. I know walmart normally has a very good price on Mobil1 5W30 but they don't carry AC Delco filters. The temptation would be to buy the oil and the equivalent fram filter in one trip.
What's the take on fram filters ? Are they inferior to AC Delco ones ?
Thanks!
Thanks!
I have used the Mobil 1 filters with synthetic filter media for years. I run Mobil 1 in all my cars. I have used the Fomoto valves to make things more convenient, but the $30-45 cost and the slower drain and the way the valve hangs down on some cars (not on C6's) have caused me to reconsider. Fumoto valves are not easy to find, except online. I buy the oil at WalMart and the filters at Autozone.
Different states have various recycling laws, but here in Florida most retailers take back the used oil if returned in see thru containers. I recall that in Calfornia, all the quick oil change joints had to accept used oil from inidividuals. I like to patronize AutoZone since I return the used oil there.
#88
MONARTOR
