Front license plate holder
I recently installed the front license plate bracket that I got from PFYC. It seems a bit loose. I velcroed the horizontal part of the bracket and screwed in the vertical bracket. Has anyone else used a different bracket? I also want to be able to remove the front plate and bracket easily. By law, need a front plate, but it looks so good without one.
If that's the one that puts the plate low, I have the same one, but used two pairs of screws. It's pretty solid, but will move up a bit - which is a good thing, as I've used it as a curb feeler once or twice. Probably the best use for a license plate I can think of
Originally Posted by Buffy
If that's the one that puts the plate low, I have the same one, but used two pairs of screws...
I am guessing that something needs to be removed in order to gain access to the back side of the front bumper. If so, exactly what should be removed, and is it difficult to do? The grill? The air filter housing? Any tips on removal?
Once you do gain access to the rear side of the front bumper, I guess the plan would be to drill some holes and then drive self tapping screws into the back side of the front bumper, yes? Or... any other thoughts or ideas?
I'd like to get this bracket on before I get a ticket... and I'm surely not going to use the stock bracket in the stock location because it looks absolutely ridiculous. Thank you.
Why waste so much money? Drill two hole in the corner of the OEM holder and zip tie it to the grill! The angle that the plate is at can be decreased by trimming the plastic along the edge of the OEM frame. The air flow decrease does not affect anything other than ultimate cooling (track/racing/???) It will surely not affect stop and go summer air flow. It never hits anything since it is above the lowest part of the bumper. I've had the curb feeler mounts and they look like crap after you do that just once.
Originally Posted by PeterC
Top Flight Repro at www.topflightrepro.com has a permanent and removable Front License Plate Bracket Assy. The removable detaches very easily. Both mounts look good and are top notch quality.
Originally Posted by aero400
I think I have the same plate bracket too. The one I have reaches behind the grill and you're supposed to screw it to the back side of the front bumper. But how in the heck do you do this? I can barely get my hand behind the front bumper at all, let alone get a drill and screw driver back there, etc.
Originally Posted by jim213
I ordered mine from them about a week ago. They are back ordered until the 15th. Looks like a nice unit.
Jim, obviously you have excellent taste
They just look like a well made unit. I actually ordered the removable one because I want to remove it when I run with my bra on the car.
Thanks, and you as well.
I think I am the first one to have installed the removeable TopFlightRepro bracket....
Here's a close-up of the permanent part of the mount. It mounts on the underside of the opening. You have to be down at the level of the bumper opening and right up to it to see this:
Now I can have it both ways!
-Jeff
-Jeff
Originally Posted by BigJoe
Best I've found.
Originally Posted by VET4LES
I have posted this before but I must say this is the best front plate setup I have seen. It helps that it is a white plate and frame on a white car.
-Jeff
-Jeff
How difficult is it to remove and reinstall the mount?
