On two seperate occasions, the Nav screen does not come on at start. The first time, I re-started and it came back on. The last time, Saturday, it would not come on at all. I tried several re-starts and turned the Nav screen on and off a few times, but still had a completely blank screen. If I push "source" and then touch the screen, it will change channels. However, since I can't see what I am touching that does me no good. I believe that it might be due to the cold as both times, the temp was below freezing.
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
Not sure where you live or if the car was kept outside, but, one very cold morning (overnight 20 degrees) after being parked in a hotel parking lot my nav screen was slow to come on...after about 5 minutes everything was fine.
Was your screen completely blank for five minutes? Or was it just acting up until it warmed up?
I live in St. Louis and the temps were very cold both times. The car is parked in my garage, but it is not insulated and does get cold in there. I suspect that the cold temp is the reason.
I posted this same question a couple of months ago. I noticed it when it was cold outside. The stereo worked and the buttons worked on the screen, even though I couldn't see them. It has happened to me several times.
I drove all the way to work one time (about 25 minutes) and it still didn't come on. Once I got to the parking lot I turned off the ignition and then turned it back on and it worked.
I have been waiting for it to happen again so I can drive directly to the dealer.
Cheers,
Same thing happend to me today. Working the autobahn without tunes is not as much fun!
