Burning MP3s for the NAV - tricks and tips
#163
Thought I would give a link for those who may be running 64 Bit Windows Operating system suchs as Windows XP Pro x64 or perhaps beta version of 64 Bit Windows Vista and who would love to burn using iTunes.
iTunes CD burning is not supported in 64 bit environment so you can not burn CD's in iTunes. Apple is aware it does not work and states so on their website
But I found this link on a different forum and it will enable CD burning in iTunes for those running 64 bit Operating systems:
http://www.gearsoftware.com/support/drivers.cfm
Download and install ""Driver installer for Windows running on AMD64 and Intel EM64T systems: download file"
Gear writes the burning software for iTunes.
I know this works in XP Pro X64, I have not tried it in Vista Beta.
#165
Leeds.io
St. Jude Donor '14-'15-'16
Can you not use the integrated windows XP burner for this?
I've thrown in a blank Cd....dragged some MP3's over (in folder in one cd and loose in another CD) then burned as data disk.
don't work.
what's up here?
don't work.
what's up here?
#166
On a nine page thread with posts from so many people with so many links and images, on the last two posts it is hard to determine which links you are referring to, and what post you are asking a question of. I suppose it would be best to use the quote feature so people know you are commenting about their post or be more specfiic in the post you make.
#167
Awesum!! I just took delivery of my C6 3 days ago. No luck with the MP3 function on the NAV. Followed your NERO instructions and it worked perfect the first time with the folders and long file names!!! Thanks for the post.
#169
anyone have a video of how to do this? because i'm going crazy here!!!
i don't know how to make folders! I'm having a break down!!!
I'm using Itunes on a macbook.
#171
I guess I lucked out because I only burned five coasters before I figured it out. However, I use a PC and MediaMonkey handled the details for me. I get the title and artist as I should and every song plays. I made six discs, so I can carry about 1500 songs in the car. On the plus side, the coasters play and display fine in the six disc changer in the non-nav red C6.
BTW, to anyone who uses MM, as soon as you get your discs burned ditch it. It will grab the associations for a lot of the audio and video you play on your computer.
#172
Ok I am stuck I burned a mp3 CD and played it in my 07 c6 some how the radio captured that playlist. I want to get rid of it. I made a new MP3 disc from ITunes, but when I put in that CD the old playlist plays. The book says there is a delete song list button but I can not find it. can anyone help
#173
Using media monkey here to burn the CDs and it works great, the only issue is the order it plays the tracks in.
1
10
11
12
13
2
3
4
5
etc, how can I get it to order the numbers properly?
1
10
11
12
13
2
3
4
5
#175
Race Car Tech
I have had success using Nero Express. I find that the type of CD makes a difference as well. Verbatim has always worked well, but others such as Memorex, and other brands, not so much.
Good luck
#176
<Album:24>_<Disc#:1>\<Track#:2>_<Title:2 4>
Eventually I decided to just install Kawal wiring harness and bought Bluetooth adapter so I could either stream music from my phone via Bluetooth or plug MP3 player into audio jack. Seemed to make more sense then burning CDs since I already have music on my Phone and on MP3 player all the time. I have not been using that method much because my three month free trial of XM has been working for 20 months. Once XM gets killed then I will start using alternate methods and maybe burn a CD or two.
Ajaste (11-24-2017)
#178
#179
Can you tell me about the Harness you have an which Bluetooth device you have?
"Eventually I decided to just install Kawal wiring harness and bought Bluetooth adapter so I could either stream music from my phone via Bluetooth or plug MP3 player into audio jack. Seemed to make more sense then burning CDs since I already have music on my Phone and on MP3 player all the time. I have not been using that method much because my three month free trial of XM has been working for 20 months. Once XM gets killed then I will start using alternate methods and maybe burn a CD or two."
