C6 Tail Light Seals From Southern Car Parts
USA1 427 (09-15-2017)
#443
#445
Brought these over the summer and installed them in about 30 minutes. Great product!!
#447
MrDoll05C6 (11-15-2018)
#449
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
If the aftermarket tail lights are dimensionally identical around the outer rim the tail light seals should work just fine. I couldn't tell you from firsthand experience though yet. If we hear differently, I'll post the new info on the forum immediately.
PDsVettes (03-12-2019)
The following 2 users liked this post by eckseleven:
leebay (08-04-2022),
southerncarparts (07-09-2019)
#453
Supporting Vendor
Try our Tail Light Seals and stop the "Dreaded Drip"
Could not leave the C6 guy's out!!! Thanks to boozman for allowing us to come over and test fit the seals on his beautiful C6
We have had tremendous response with the C5 tail light seals. See the below threads for feedback. Now we have launched the same type of seals for the C6!!!!!!
http://forums.corvetteforum.com/show...1&forum_id=103
http://forums.corvetteforum.com/show...68&forum_id=53
What is the dreaded drip? The dreaded drip is when you just finish washing and drying your Corvette, everything looks awesome.....You walk around your pride and joy for that one last look and there it is, the DREADED DRIP. It is the water that collects in your tail lights (because GM did not put a seal between the tailight and the body) and then drips out and down the rear bumper 5-10mins AFTER you finish drying your car. It is also the water that collects in the taillights and attracts all the road grime when you first take your Vette for a spin after a good washing.
Southern Car Parts Tail light seals solve the problem FOREVER, guaranteed!!!!!
Our tail light seals take less than 7 minutes to install, come with instructions, and are pre-cut to be an exact fit every time. Only tools needed to install them is a T15 Torx head and window cleaner. No gluing as they have a self-adhesive backing.
The seals are made from a high quality rubber that is UV resistant, temp resistant, and water resistant....THE SEALS ARE GUARANTEED FOR THE LIFE OF YOUR CAR. If they ever rot, crack, tear, or fade we will REPLACE THEM FREE OF CHARGE!
You will NEVER see the DREADED DRIP again!!!!!
Price is $24.99.
Click here to order.
Corvette C6 Tail Light Seals
If you aren't happy just send it back for a full refund
www.southerncarparts.com
David
Price is $24.99.
David
#456
Ordered my set>>
Update >>, installed seals and went perfect. Super easy and look/fit perfectly …
Really wanna stress that the rubber seal is perfect and the tear drop design of the gasket truly is perfect for sealing and making fitting the light to body for screw alignment a breeze not like the phony foam imposter !
Don’t waste your time or money > buy the right seal kit once from SCP and be done with it forever>
The following 2 users liked this post by C6moblife:
southerncarparts (08-04-2022)
