2004 REGULATIONS!!
2004 REGULATIONS!!
What kind stuff can the government require?????
Will HP suffer??
:confused:
Will HP suffer??
:confused:
Re: 2004 REGULATIONS!! (l2vette)
tom...
Re: 2004 REGULATIONS!! (Tom73)
Tom is right to a certain extent. Many regulations are made
by government sanctioned beauracracies like the EPA
and NTSB without even a vote in Congress. The Congress
and the President have given a good amount of authority
to these beauracracies for control over our lives.
Paul
Paul
Cruise-In IV Veteran
Cruise-In V Veteran
Re: 2004 REGULATIONS!! (fifimonster)
any major new specific regs coming due for 2004 that might affect performance?
[Modified by CORKVETTE1, 10:14 PM 9/2/2001]
I understand the 2004 model year (i.e. sometime in 2003) will require automakers to warranty emissions for 125,000 miles instead of 100,000 miles. There may be a new set of lubricant specifications to help prolong catalyst life.
☠☣☢ Semper Ebrius ☢☣☠
uniform bumpers:
ALL BUMPERS MUST BE 38 inches high"
j/k
j/k
Re: 2004 REGULATIONS!! (Griff2002)
All fluids maybe required to be synthetic! :D
Ya if it woint fo da big howly boss man
in da white houz, we be sittin fat rat man.
Thats what I heard the last time I was in Hono. :lol:
Any thing that they want. Another reason to make sure about who you elect.
tom...
tom...
1 Post
CF Pit Crew
Cruise-In I Veteran
Cruise-In II Veteran
Almost CI III Veteran
There will be no drastic changes for 2004. At this point, it is too late to make major changes in 2004 designs. Longer term, there is still a lot of investment being made in alternate fuels, hybrids, etc. There are also still improvements to come for the good old internal combustion engine. Full electronic valve control, start/stop stratgies, lean burn w/ NOX traps, etc. A lot of these new technologies will require 48V systems, but don't expect to see them in 2004. More towards the end of this decade is more likely, with the odd few applications possible in the 2005-2006 time frame.
Received 1,973 Likes
Re: 2004 REGULATIONS!! (70L46)
I believe the new electrical systems are being quoted by most sources as "42 volt".
I don't think there are major changes in emission control cast in concrete yet, but the two sources that are being looked at are evaporative emissions and cold start emissions. Modern cars have so little tailpipe HC, the major source is becoming evaporative emissions, so we can expect more robust evaporative control systems within the next few years.
About 80 percent of emissions generated during the 40 minute EPA certification test come during the first two minutes of operation - the time it takes for the converter and O2 sensor to warm up enough to be effective allowing the engine to go into closed loop mode, so some kind of preheaters will probably also be added in the not to distant future.
Neither more robust evap controls nor preheaters are likely to reduce performance, but they will add a little weight.
I think electronically actuated valves are still in the distant future - say at least five or more years - but the 42 volt systems will be necessary for both electronically actuated valves and catylist/O2 preheaters.
The new electrical systems are likely to be dual voltage - 42/12 volts, with only a handful of new systems using 42 volts. Most on-board systems will continue with 12 volts.
Duke
[Modified by SWCDuke, 8:03 AM 10/21/2001]
Duke
Re: 2004 REGULATIONS!! (SWCDuke)
