Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- How to Install Front License Plate Bracket
Step by step instructions for do-it-yourselfers.
C6 Front License Plate Bracket
#1021
After taking a closer look at the intake it appears this bracket will not have any effect at all on air flow to the filter. I cant see any direct path to the air cleaner at all! It looks like the only air comes from the sides. Am I missing something? Anybody make scoops to help airflow get to the filter?
#1025
lisc bracket fell off!!
has anyone had problems with the tape on lisc. bracket? mine fell off ,
I know I put it on correctly, put one on another car no problem,
maybe faullty tape is all I can geuss, kinda sux when you have $200 worth of bracket fall off !
#1027
You should have contacted us and we would have sent you a replacement the problem you encountered is not normal and we would have been more than happy to help you
#1028
topflight,
Im sorry I didnt mean to come across like I did. It actually fell off a couple of weeks ago. and have had a lot of stuff going on.
I was wondering has anyone else had this same issue? are you using a different brand of tape ? installed a vr bout 2 years ago
no problems at all , now on the lmb vette just fell off cleaned it well good temp. and everthing.
I really love the way your brackets look ,
and they are good quality.or I wouldnt have been a repeat customer, and I have probly sent a few more customers your way, locally they are real tough on front plates
thanks Bill
thanks Bill
#1029
topflight,
thanks Bill
thanks Bill
#1030
Got my top flight front mounting license plate bracket last week, installed quickly and easily and looks much better than the bracket that mounts on the nose of the vette. The instructions recommend using "denatured alcohol or mineral spirits" to remove any wax so that the double sided tape on the bracket adheres well. For those of you wondering where to get denatured alcohol or mineral spirits...Most local hardware stores carry both.
#1031
#1033
Just got my c6 this weekend. The previous owner had the factory plate holder. I have the two screw marks that are fairly small. Is there any way to life the license plate up slightly with your bracket? Thanks!
#1035
In Stock!
The Top Flight Reproductions C6 front license plate bracket is the best looking mount available and it's legal in all the two plate states unlike some of the other after market front plate solutions. It follows the contour of the front bumper. Installs easily without lifting the car. Requires no drilling for attachment like some others do. Our bracket is priced considerably lower than other after market solutions and is made in the USA .
All three Top Flight Reproductions front license plate brackets are in stock and ready to ship. Visit our website at www.topflightrepro.com or call 781-279-1279 and ask for Ray.
C6 Z06 Removable Front License Plate Mounting Bracket
C6 Removable Front License Plate Mounting Bracket
C6 Permanent Front License Plate Mounting Bracket
#1038
