Do 19x11 Rear Wheels Fit Stock Rear fenders??
Hi I am concidering adding Z06 style wheels to my 2005 coupe. I know that the 19x12" Z06 wheels wont fit the stock rear fenders, but do the 19x11" Rear Wheels Fit Stock Rear fenders??
http://www.radicalwheelsinc.com/inde...d&productId=74
Thanx
Thanx
Pic of same wheels (different color) on my car. Protrudes 1/4" at top of fender with 305/30s on them. I like the look (looks full).
It's raining, or I would get you a dead on rear shot.
1 Post
Originally Posted by C6-Stingray
So you guys are sure they wont hit the fender when the tire is fully up?
Been on since C6 delivery in November.
Dealer installed.
19 X 11 Factory Reproduction Z06's with stock size run flats.
Photo Sharing - Upload Video - Video Sharing
CCW's, custom made for our cars. 19x11. perfect fit. Running them with Z06 factory runflats
What offsets are these tires? I also am looking at the 19x11 in the rear for autocrossing. I'd like to slap a set of 315/40R19 Hoosiers on them. Would that rub the fender?
This calculator will help you with what Rim width is required. You can also compare your stock tire with your new tire to see what affects it will have.
http://www.1010tires.com/TireSizeCalculator.asp
I'm hoping someone has the offset answer I was told that we have almost 2" of inside clearance for the wheel to go more inside but I'm not sure if that is true or what that means the offset would be (or if anyone makes a rim like that...)
How is the offset on the 19x11" rear z06 wheels?
Since they are 1" wider than the stock wheels, do they go inside
the fender more, or stick out more, or a bit of both?
Thanx
Thanx
Thanx
Thanx
Try http://www.1010tires.com/WheelOffsetCalculator.asp and/or;
http://www.rsracing.com/tech-wheel.html
Read the definitions of offset vs backspace/frontspace.
Offset is very important to wheel/tire fit. But the definition of fit is difficult. My shoe size is 10 1/2 but I can force my foot into a 9 1/2 OR wear an 11 1/2. Do those sizes "fit"?
