What causes front tire cupping on a low miles C6 ???
My 2006 coupe only has 6,800 miles on it.
Treadwear is great, but the front tires are severely cupping.
It’s got the Z51 supercar tires on it.
It’s causing a vibration through the steering wheel at anything over 50 MPH.
At the suggestion of my local dealer I took it to Goodyear for an inspection.
They saw the problem and measured 7/32 of tread remaining. Tires are 9/32 when new.
At less then 7K miles they have only 25% wear on them so they should be good for 20,000+ miles.
I’m still within 12mo and 12,000 miles so I’m hoping for a 100% replacement here.
The Goodyear place couldn’t check the alignment because they were worried about scratching the rims so I have to take it back to the dealer for that. Appointment is for Friday.
After that’s checked it will be decided if Goodyear or GM is fixing this.
Any other suggestions?
Has anyone else gone through this in the first year w/ relatively low miles?
Should I accept a prorated 50-75% credit or push for 100% reimbursement?
Thanks,
Shawn S
Thanks,
Shawn S
St. Jude Donor '07
You probably need the front end aligned. Mine is the same way. I have almost 22K mies on the Super Car tires. I will need need new tires in the spring, so I'll get the front end aligned at that time.
If you have cupping in the center and NOT shoulder wear then you probably are overinflatting your tires. Go and check the pressure.
If the wear pattern is uneven then you have an out of alignment suspension component most likely. (Or it could be a bad tire that wasn't formed properly at the factory)
Originally Posted by BigGeek
Z51 GY RunFlats are rated for only 10K miles!
It is not written in stone how long these tires will last, it depends on the type of driving. Under hard use, 10K is not unusual. Easy freeway miles could result in 22K. These are a soft compound tire, and anything from under inflation by a few pounds to a slight misalignment will show up much faster than on a harder compound tire. So you may end up with a bad tire with a good amount of tread left. Good luck with a replacement tire at the dealer, let us know what happens.
So what are people replacing them with. The same tire or something else and how are they lasting/performing? I am used to getting 60,000+ on my Suburban or Avalanche. This could be expensive driving! I may have to reconsider my decision to buy.
Mickey
Mickey
Location: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
I got approx 8500 miles on mine. I drive the car hard, but I don't kill it with smokey burnouts etc. Rears were worn out to the wear bars, fronts had a small amount of life left.
I changed out to BFG KDW-2's. They aren't run flats but vastly better in all aspects.
cupping = alignment
you're probably "scrubbing" the tires going down the road like this / \
From www.ask.com:
Chevrolet, for example, issued a technical service bulletin (#86-90) that recommended resetting the toe to zero to cure an outer shoulder wear/cupping problem caused by excessive toe-in on 1985 & '86 Caprice, Monte Carlo and light trucks.
From www.ask.com:
Mickey
Mickey
Luckily BFG and several others make cheaper replacements that supposidly handle better for less $$$. They are however not run flats.
60K on a vette tire. Thanks for the laugh!
Originally Posted by vetdude
cupping = alignment
Get Some!
Mickey
Mickey
cupping = alignment
From www.ask.com:
From www.ask.com:
You have to pay to play. To get all that grip you need a very soft compound. Hence the tires wear down faster. (A lot faster!) Every time I come home after some good driving, I have rubber plastered all over the rear wheel well and hubs. It's about $.15/mile on the tires. Hence forth why I only drive mine 10K a year.
I read here about people getting 20K or more out of a set if they don’t “smoke em up” every chance they get.
The wear pattern of the “cups” is even across the entire face of the tire.
Maybe slightly worse on the outer edges.
And it’s exactly mirrored on the other side of the car.
The rear tires are perfect.
I don’t think it can be blamed on high or low pressure.
Pressure is maintained at 30-31 cold and checked with a digital gauge at least every other week.
Originally Posted by Whiterock1
Sounds like toe is out--cupped outside too negative; inside, too positive. I can't believe a tire dealer won't do an alignment! The car drives onto a flat rack, generally. Then gets raised from there.
Some attach to the outside of a rim and some attach to the inside.
If they don’t have the proper tips, it could scratch a chrome rim.
Yes, but they have to mount an alignment device onto each wheel to check the four corners and measure the adjustments.
Mickey
Mickey
Well, here’s an update:
I took the car to my local dealer for a 4-wheel alignment last Friday.
It was slightly off, but not nearly enough to cause the wear I was seeing.
They brought the numbers back into spec and sent me back to the tire store.
Back to the Goodyear….
The manager submitted the claim to GY home office and said they’d get back to me in two days with a decision.
They argued that tire cupping was more of a “driving annoyance” and wasn’t really covered by the warranty.
Retail on the Supercar fronts is 465 each and their first offer was to replace the tires for 167 EACH based on 2/32 of wear and 7K miles.
I objected to that offer and told them to do better.
They called back today and offered 92 dollars each installed & balanced.
I took that offer and they ordered the two front tires.
I guess that’s a fair resolution since I did get about a years worth of mileage out of them.
Did I do good?
Shawn S
Did I do good?
Shawn S
I always thought cupping was a shock absorber problem....
http://www.kaltire.com/commercial/me...es/cupping.php
http://www.partsamerica.com/MaintenanceTireProblem.aspx
