Z51 performance gear ratio????
#61
Well heck...I have an LS-2 and I for one don't think that it's a better motor because it has a higher CR. The LS-3 should be a stronger running motor simply because of the tweaks in it for that 30 (or whatever...LOL) extra HP. Notice I said "STRONGER" motor....and not necessarily "BETTER" motor. For someone to hang their hat on the fact that one motor has about a .5 (or whatever...LOL) advantage in CR is kinda like grabbing at straws.....
#62
Received 2,061 Likes
The LS3 doesn't need higher compression because of the improved head design. It's why some guys with LS2's swap to LS3 heads just to try to stay up.
#64
#65
A base 6-speed with 3.90 is extremely close to a Z51 gearing. Base w/ 3.90 is actually more advantageous for the 1/4mi because of the shorter 4th gear, topping out around 135mph vs 150mph. So 4th will pull quite a bit harder before crossing the line.
