F-55 Re-flash / Corrective or Performance Mod?
CF Senior Member
I believe I read the F55 system in the 2007 C6 was improved to offer a greater differentiation between the two settings. I also recall reading there was a re-flash for the F55 system.
With the magnetically responsive F55 suspension system, the state of the MR fluid changes in proportion to the strength of the magnetic field applied. I also realize the F55 system reacts in relation to various inputs such as braking, steering, throttle, lateral acceleration, relative position, relative velocity, vehicle speed, steering angle, lift/dive angle, yaw rate, road inputs, etc. to provide variable force resistance.
What exactly is the F55 re-flash for? I don’t recall reading about any problems with the F55 suspension system so if the re-flash isn’t corrective, is it to improve system performance?
Does the F55 re-flash alter the parameters of the various inputs to increase dampening resistance and/or does it change the electrical current to increase the magnetic field to alter the MR fluid to an even denser state....yielding greater performance-oriented dampening?
Location: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
What exactly is the F55 re-flash for?...Does the F55 re-flash alter the parameters of the various inputs to increase dampening resistance and/or does it change the electrical current to increase the magnetic field to alter the MR fluid to an even denser state....yielding greater performance-oriented dampening?
Changing the computer's register values (within the F55 program) would conversely change the output current controlling the dampening.
I'm curious as to why reflash of the entire program was required to start, unless reflashing one (or more) register values couldn't be accomplished without doing 'em all.
"Old" EPROMs used to work like that, but I'd have thought the PROMs used in todays cars would've been of the EEPROM variety.
Now this is a question for "Shopdog" if ever there were.
i don't know about a reflash but i will tell you that with my 07 F55 you can tell immediately when you switch from touring to sport, even on a "regular" street. i'm not sure that prior years were that noticable so it may be different.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Shopdog does not have the F55. He has the base suspension with Z51 anti-sway bars, and Bilstein HD shocks. He is QUITE pleased with his setup.
CF Senior Member
Again, I wonder what the F55 re-flash is for....to correct some problem I am not aware of or if the re-flash is to enhance performance of the system itself by means of altering the input specs and/or the electrical current/magnetic field.
Hopefully, some of the more qualified tech people will have some knowledge about this. Overalll I'm very happy with the F55 system but if a re-flash would enhance it to an even higher performance standard, that would be great.
Might do both, Wayne.
As I remember the change was actually done for 2006 models to make a greater difference between sport and tour modes.
Sorry I couldn't tell you.
I did drive a 2005 vert with F55 for 2 days. It was definitely hard to tell the difference unless you hit a real bumpy road. Even then I considered the difference minimal.
But in the end I got the Z51 for my own car.
CF Senior Member
I definitely read they changed the F55 system to provide a greater differentiation between tour and sport modes in either the 2006 or 2007 model year. I did read (somewhere here in the forum) there was a re-flash for the F55 system. It seems a mystery so....
I stopped-by my local dealership yesterday and spoke to my service advisor. I asked him (and I put it in writing) when he had time, to confirm whether or not there is an F55 re-flash and assuming there is one, to find out exactly what it does.
I hope to hear back from him later this week.
