Cleaning rear hatch lid
I just took delivery of a new Z06. The dealer didn't have much time to really clean the car up and to do a thorough detail job. So in the end I am cleaning up their mess. Under the rear hatch compartment lid the dark grey area near the latch. I used a simple foaming window cleaner and wiped it with a towel. But when I was doing this it was like the window cleaner was removing the color from the finish. The window cleaner is GM window cleaner that is in rattle can. Anyone else run into this? Sorta strange as I am not sure if the dealer applied something to the underside of the hatch lid. I then tried plain water on a rag, and where the window cleaner was used it seems to wipe cleanly, however where the areas were untouched by the cleaner it seems that the water beads up like it had wax or something else applied to it.
I’d stay away from any window cleaner that has ammonia in it. I believe the GM stuff does contain ammonia but I’m not 100% sure. I have one very small spot on my hatch that I believe was caused by using a cleaner with ammonia!
The finish on my rear hatch area appears to be mildly damaged from the PDI/clean-up. I recall someone used a product called Mother's, Back to Black to fix it up. I have never used this product and do not know how it would work. Maybe someone who has used it will chime in.
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Same thing happened to me on my 05. But after the first cleaning it never happened again. I am beginning to think it might have been a release agent used in the mold for the hatch piece. Mine looks the same as when new but never had the black/grey come off again after the first cleaning.
I think you will be okay.
St. Jude Donor '06-'07
"303 is THE LEADER in UV screening technology. 303 Aerospace Protectant really is like "SPF 40 Sunscreen ... For Your Stuff." Regular use gives 100% Prevention of UV caused slow-fade with regular use. No other "protectant" beautifies as intensely, protects as powerfully or lasts as long.
The World's Most Manufacturer-Recommended Product:
Because of its enduring cosmetic properties, the resistance of 303-treated surfaces to dust, soiling, and staining, its water repellency and unparalleled protective characteristics, manufacturers worldwide recommend 303 Aerospace Protectant.
303 Aerospace Protectant keeps UV-sensitive materials “like new” year after year. Use on Rubber: Tires, neoprene, latex, door and trunk seals, weather-stripping, EPDM rubber roofs, CV boots, waders, wet suits. Vinyl: Convertible tops (and the clear vinyl windows), isinglass, marine seating, tonneau covers, car bras, covers, spa covers, pool covers. Inflatable boats: Hypalon, PVC and urethane blends. Gelcoat fiberglass: Boats, RV’s, snowmobiles, jet ski’s. Plastics/acrylics/polycarbonates: Lexan® and acrylic panels/windows/windshields/covers. Carbon-fiber/resin composites: Fishing rods, “nude” bike frames. Finished leather: Upholstery, motorcycle leather, trim, tack, fine apparel. Pool & Patio: Plastic furniture (not fabric), pool inflatables, slides, covers. Sailcloth: Dacron® and monofilm."
Well, I tried the 303 Protectant, and I tried some Mequires Vinyl and Rubber treatment. Both will turn my rag black just like the window cleaner. It is strange as heck, I have not tried to back to black stuff yet. Sorta scared to try that one!
6th Gear
Success?
I know this was a long time ago, but did you ever get the issue resolved with your rear hatch trim? Same issue with my 07 Vette. Any help or guidance is greatly appreciated. Thanks
Todd
