Pictures of Vette-Air Inlet and Halltech Venom Install on LS2
Location: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
simple test, let the car completely cool. take a filter side shroud temp. reading, start her up, let her idle up to operating temp. (with hood closed), open the hood, take a shroud temp. reading, close the hood, let her idle until the fan comes on, let her idel for 5 more mins., take a shroud temp reading.
imo, anytime you can isolate engine from intake temps. the more performance that is potentially ava.
Supporting Vendor
St. Jude Donor '09
I am going to put a link to this thread on my website for install. Very Very nice! Thank You!
Jim Hall
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
No problem Jim...My Killer Bee arrived today. I sent you an email. The original install was here: http://forums.corvetteforum.com/show....php?t=1776343
Zpirate must have figured if I did it once I probably wouldn't screw up his...
Mine looks like this now:
Thanks Jim. And thanks to Modshack for most of the work. I lent him a hand and took the pictures.
What does the Killer Bee offer that the Stinger doesn't?
I have the Stinger and did the poor boy mod that was on the forum awhile back. That is the one where you open up the bottom portion of the radiator shroud. Seems to work OK, but the engine compartment does gets a bit more grit.
Awesome write up but quick question......Can I use the scoop with a K&N too? And another question what would happen if u just make holes where you cut to bring in more air; is the scoop neccasary?
When using the Vette-Air with the factory LS3/LS7 air breather(which works very well) most of us have found that the discharge air from the Vette-Air is forced into the open end of the air breather and the result is turbulence across the MAF sensor, causing all kinds of problems.
It is easily solved by adding a flat diffuser plate on top of the Vette-Air discharge opening using the two rear bolts. I made a plate 3.5" X 18" from 1/8"plexiglass and sealed the front of the plate to the bumper beam using 1/8" ID vacuum tubing slit lengthwise. The diffuser plate I added does the same thing that the closed end of the Halltech filter does. It causes the air to flow around to the sides where the air breather can still digest it, but prevents turbulence from screwing up the MAF readings.
Even with the diffuser plate, you still get the all the cold air as the air that flows around the flat diffused plate creates a curtain of cold air surrounding the breather's intake opening that the air breather ingests.
#34
hey guys , i just got my ls2 and halltech , i see now corvette air is not recommended cause of turbulance have you guys cut the corner of the shroud to see if it works better ? and any instructions?
