Any regrets
Old Aug 28, 2007 | 10:32 AM
GoDevil's Avatar
GoDevil
Cruising
Default Any regrets
Hey guys. Anyone have any regrets with there new corvettes. Im looking at an 06 with 5000 miles for 60k Canadian.
How can u tell if its a Z51 or not and whats the difference.
Old Aug 28, 2007 | 10:58 AM
FIRE CAT's Avatar
FIRE CAT
Default Z 51
I just love my 07. Z 51 's have cross drilled rotors on 06's.
Old Aug 28, 2007 | 11:02 AM
HarleyEarl1953's Avatar
HarleyEarl1953
Actually, something I didn't know until a recent visit to the local dealership is that 2007's with the F55 option also have cross-drilled rotors as well. Don't know about the previous years, but the car I drove was a 2007 with 5000 miles and the F55 option with cross-dillred rotors. Always learning something new!
Old Aug 28, 2007 | 11:04 AM
drbonebreak's Avatar
drbonebreak
Default No regrets
No regrets at all, this is the best corvette ever. I can't imagine somebody not being satisfied by the car. Having said that, there are some areas that could be improved. You will learn a huge amount by reading your way through the C6 FAQ posted at the top of the forum page. Good luck.
Old Aug 28, 2007 | 11:05 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
2007?
If the car is stock and EXACTLY as it was from the dealer, I don't think the F55 had crossed drilled rotors. After market maybe but not from the factory.
2008? Yes, you can get the CD rotors on the F55 OR the Z51.
Elmer
Old Aug 28, 2007 | 11:06 AM
Vette_DD's Avatar
Vette_DD
If you can look inside the car, all of the option codes will be on a white sticker on the left inside door of the glovebox. "Z51" will be listed there. Usually, you can tell by looking for drilled brake rotors.
Here's what the Z51 handling package adds:
The Z51 package, available with all PEGs on both Coupe and Convertible, is designed for the
performance enthusiast. The package includes:
• Specific shocks and springs designed for more control
• Larger stabilizer bars
• Larger, cross-drilled brake rotors (340 mm front/330 mm rear) and track-tuned linings
• Engine oil, power steering and transmission coolers
• Specific higher-grip Goodyear EMT tires with asymmetrical tread patterns
• Specific six-speed manual transmission with quicker gearing
Note that the last line only applies if it's a manual tranny.
Old Aug 28, 2007 | 11:15 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Love my '05/Z51/M6....greatest combination of power & handling that I've ever driven. The Z51 package includes the cross drilled rotors, EMT Supercar tires, closer gear ratios, engine & transmission oil coolers, larger front & rear sway bars, different shock valving, lube fitting for the rear suspension & maybe a couple of other items I've missed. You can't go by just the drilled rotors since they may be an aftermarket replacement or as others noted, part of the later F55 option. Best way to confirm is to check the build code on the glove box door label.....I don't remember the code, but if you do a search on the Forum, you can find it. Other way is to check the lower rear ball joint for the grease fitting! As for price on a used '06....Canadian dollar is around .95 against US dollar, so your $60K Canadian is ~$57K US. You don't say how the '06 is optioned (other than Z51), nor whether Coupe of 'Vert, buy that sounds like a high price.
Old Aug 28, 2007 | 11:17 AM
hulksdaddy's Avatar
hulksdaddy
Originally Posted by eboggs_jkvl
2007?
Elmer
2007's with F55 have cross drilled rotors.
Old Aug 28, 2007 | 11:22 AM
User 020720's Avatar
User 020720
The only regret I have is not buying this car sooner.
Old Aug 28, 2007 | 11:33 AM
ClovisFox's Avatar
ClovisFox
Default No Regrets Whatsoever!
Just this month I upgraded from a Y2K Z51 to a 2008 Z51. No regrets at all. The C6 is an amazing machine, and a thrill to drive.
Good luck on your decision.
Gene...
Old Aug 28, 2007 | 12:01 PM
BOBsC6's Avatar
BOBsC6
Bought a 2006 Monterey Red Coupe in April last year and love it. I have no regrets, but the wife regrets that it is not a Daytona Sunset Orange. I drive it as often as I can.
Old Aug 28, 2007 | 12:04 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I certainly have no regrets about my (non-Z51 optioned) C6. It is one of the most reliable and fun cars I've owned. The Z51 option has many nice features designed for the parking lot autocross or gymhkana enthusiast. The additional cooling and larger brakes are a plus but IMO the drilled rotors are not. The rotors were drilled according to the 'Father of the C6' Dave Hill...just for looks. The Z51 has a specific suspension as well as slightly different transmission gear ratios. I know the GM web site lists all of the features of the Z51 option.
Z51 optioned or not, I think you will find the Corvette C6 to be a tremendously fun car to drive.
Old Aug 28, 2007 | 12:10 PM
kwickag's Avatar
kwickag
Mine's that way and it is bone stock.
Old Aug 28, 2007 | 12:16 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
I have only one regret, I wish I would have kept my C5 in addition to buying my new C6. I love my new roadster, but I also find myself missing my old car.
There may be another C5 in my future.. maybe a supercharged one..
Old Aug 28, 2007 | 12:18 PM
garye's Avatar
garye
St. Jude Donor '12-'13-'14-'15, '21
Old Aug 28, 2007 | 12:26 PM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
None, None, and None
Old Aug 28, 2007 | 01:17 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
No regrets.
60K Can. seems a bit high
To Any regrets
Old Aug 28, 2007 | 01:19 PM
RED2008Z06's Avatar
RED2008Z06
No regrets...check the label in the glove box, buy it enjoy...
Old Aug 28, 2007 | 01:21 PM
LSD 2005's Avatar
LSD 2005
No regrets... I love my C6.
Old Aug 28, 2007 | 02:04 PM
REVAK's Avatar
REVAK
NO regrets, not sure about the exchange rate on the purchase price, the previous reply's covered the Z51 question. Good luck if you decide to pull the trigger, you will enjoy the car.
