Need more help please, can't get new fob to program
Hi,
I did what you said and at the end, A beep will sound and the DIC will read
READY FOR FOB #1. I left it in there for over 5 minutes then the DIC went blank. Not sure what happened. What should I do from here? I didn't check but does the new fob come with a battery?
This is the way I did it
United States owners are
permitted to match a new transmitter to their
vehicle when a recognized transmitter is
not available. The procedure will require
three ten minutes cycles to complete the matching
process. Do the following:
1. The vehicle must be off.
2. Place the new, unrecognized transmitter in
the glove box transmitter pocket with the
buttons facing towards the passenger side.
3. Go to the rear of the vehicle and insert the
vehicle key into the key cylinder located above
the license plate. See Hatch/Trunk on page 83
for more information on the key cylinder.
4. Open the trunk.
5. Turn the key five times within five seconds.
6. The DIC message will display
OFF-ACCESSORY TO LEARN.
7. Press the Acc. button (ignition switch).
8. The DIC will read WAIT 10 MINUTES and will
count down to zero, one minute at a time.
9. The DIC will display OFF-ACCESSORY TO
LEARN again.
10. Press the Acc. button (ignition switch).
11. The DIC will read WAIT 10 MINUTES and will
12. The DIC will display OFF-ACCESSORY TO
LEARN again.
13. Press the Acc. button (ignition switch).
14. The DIC will read WAIT 10 MINUTES and will
15. A beep will sound and the DIC will read
READY FOR FOB #1. At this time, all
previously known transmitters have been
erased.
16. Once the transmitter is recognized and
programmed, a beep will sound and the
DIC will display READY FOR FOB #2.
If you have additional transmitters to program,
take transmitter 1 out of the transmitter pocket and
place transmitter 2 in the pocket. This can be
done repeatedly until up to four transmitters have
be programmed. The DIC will then display
MAX # FOBS LEARNED and will exit the
programming mode.
When you are done programming transmitters,
press the Acc. button (ignition switch).
Note: If your car has the manual tranny, I think you have to have the car in reverse, even though the engine is off, during this process.
Thanks, Jerry
4. Open the trunk.
LEARN again.
LEARN again.
erased.
programming mode.
Thanks, Jerry
